BRYSTON BDP DIGITAL PLAYERS NOW Roon Ready
0 Members and 1 Guest are viewing this topic. Read 189695 times.
Nick V
Re: BRYSTON BDP DIGITAL PLAYERS NOW Roon Ready
« Reply #400 on: 11 Apr 2018, 05:27 pm »
I use a Netgear AV200. Works perfectly with my BDP. Runs through a wall outlet and ethernet CAT cable from my BDP.
I have a Lyngdorf DPA-1 between my DAC (Gungnir) and the BDP-1.  BDP-1 -> AES -> DPA-1 -> Coax -> Gungnir.
DPA-1 doing crossover, RoomPerfect processing.  Sounds supercallifragilicious.
Excellent, thanks guys.
Both using the BDP-1 as a Roon endpoint?
CanadianMaestro
« Reply #401 on: 11 Apr 2018, 05:28 pm »
I do not use Roon. I playback FLAC from attached drives with MPad control.
artur9
« Reply #402 on: 11 Apr 2018, 10:59 pm »
I use my BDP-1 in MPD mode, being remotely fed from MinimServer.  I tried Roon but it had no value for me.
alexone
« Reply #403 on: 29 Nov 2018, 07:19 pm »
hi, folks!
i'm using Roon now for the first time. :oops:
i loaded my folders and it seems that Roon adds (and plays!) songs that i never loaded to my folders... :scratch:
anyone out there who cn tell me what i did wrong??
thanks,
al.
zoom25
« Reply #404 on: 29 Nov 2018, 07:34 pm »
Preferences -> Storage
Check the folders you have selected. Perhaps you have some default folders selected there. Are you logged into Tidal?
alexone
« Reply #405 on: 29 Nov 2018, 08:08 pm »
hi, Zoom!
no Tidal connections that i am aware of...
davidtgoh
« Reply #406 on: 24 Jun 2022, 01:27 pm »
I'm posting because I'm having ]two issues with my BDP-3. I've tried to email James, Mike and Chris, but have not gotten a response (unusual in my experience).
Since February, Quboz will play, then stop, then resume. The longer it plays the more frequent this becomes. It had been working fine until then.
As of a few days ago, when I began using Roon a little more (running from a headless MacMini), the BDP will not switch back to MPD from Roon mode. The first time this happened, although powering down and powering up did not resolve it, restarting the BDP-3 from the menu did get MPD back on. However, having switched again to Roon mode, it now will not switch back to MPD. I’ve gone through Services a number of times, and MPD will not shut off when unchecked, but the BDP continues to be locked in Roon mode. I upgraded firmware in late May - so don’t know if this has something to do with it.
My BDP is in service mode, ID 26
'm a long standing Bryston user. SP1.7 bypass, BDP-3, BDA-3, BOT, 6B-ST, 4NRB, Vandersteen 5's, and very much enjoy tracking this group.
[email protected]
NekoAudio
    • Neko Audio LLC
« Reply #407 on: 24 Jun 2022, 02:30 pm »
Do you have a streaming service enabled for Roon, and also have Roon Radio turned on?
OTM
« Reply #408 on: 25 Jun 2022, 06:38 am »
I had something similar only it was with SharePoint
BDP2  updated to   S2.45 2022-05-26
MPD  worked fine until I switched to SharePoint (which did work)
However I could not re select MPD  I tried rebooting as well as unplugging BDP remained locked on SharePoint.
I finally reloaded the firmware and MPD. Is working again.
David
