What's the gap between best and worst?
So what's the story?
Disk space is cheap. I chose WAV. Sure FLAC, ALAC, and WAV *should* be the same, but with WAV I don't have to wonder if I'm missing anything.Kevin T
Is a WAV music file just a file name and the PCM data and nothing else?
The inability to retain meta data makes it impossible to organize a large library. For this reason, if I were going to go uncompressed, I'd use an AIFF file format.
I've talked about this subject previously on both Audiocircle and Head-fi. I've done lossless format testing on both a Bryston BDP-1 and various Macbook Pros (w/SSD) and iMacs running Audirvana Plus and Amarra. I know that Audirvana and the Bryston load up the song into the buffer in advance, so it shouldn't matter what format the material is in, as long as its lossless I compared ALAC, FLAC, AIFF, and WAV...I didn't end up testing FLAC uncompressed however.Few observations: ALAC requires the most amount of processing. Try loading an hour long lossless track into Audirvana Plus and you can visually see the buffer line. ALAC takes the most time. FLAC is a bit better. AIFF and WAV are significantly better. WAV very slightly beats AIFF.After testing and some assistance, I found ALAQuoteC to the be the worst, followed by FLAC, and very close between AIFF and WAV...Ultimately went with WAV. It works and sounds the best across every system from any year or platform.Full discussion here: http://www.audiocircle.com/index.php?topic=139572.0Have fun
