Sonneteer Campion
radiomanjh
Sonneteer Campion
« on: 18 Jun 2016, 11:51 am »
Just wanted to know how the base response would be in a 14' X 20' room with the one side completely open to other rooms?  My speakers are the Nola Boxer.  Thanks for any info!
haiderSonneteer
  • Managing Director and Founder at Sonneteer
    • Sonneteer, made in Britain since 1994
Re: Sonneteer Campion
« Reply #1 on: 6 Jul 2016, 01:38 pm »
Hi Thanks for the question. Your speakers are highly sensitive so you should have no problem at all. I don't know them specifically for performance but on spec you should be fine.
I hope this helps.
Haider
