Floor under the speakers question for new room
0 Members and 1 Guest are viewing this topic. Read 5859 times.
S Clark
Re: Floor under the speakers question for new room
« Reply #20 on: 19 Jun 2016, 01:29 pm »
Many years back, my students did a laser project with holographs.  Our issue was a highway about 70 yards from the lab.  We solved the problem with a truck inner tube with a pretty massive sand box mounted on top of it.
mcgsxr
« Reply #21 on: 20 Jun 2016, 03:17 pm »
My fav trick to take most of the airborne vibrations out of the equation is the media closet - ie park all the gear outside the listening room.  I built one into my basement when we finished it off years back.
For actual speaker to floor - I ended up with 5/8 plywood over Delta MS - basically instead of using Dricore, we went with a 2 layer DIY.
Then underpad and carpet.
So likely not a solution for you for your speaker isolation desires, but it is what I did.  Very happy with it and my Maggies in my basement.
