0 Members and 2 Guests are viewing this topic. Read 68700 times.
AFAIK, all Danny's N-series kits use the PDR but, "his" NEO3 PDR's came with the deep back cup, I don't know if there is a source for these ? Rich is correct, the PDR without faceplate or rear cup will work in the NX-Ottica but one of the custom Serenity pairs will be required for the NX-Tremesjay
Danny, that's one unit's design that I would like to listen to...Yes, I know, I only have to buy a pair from you.Guy 13They look nice, will look nicer with the drivers installed.
Next time your back in Canada, fly out west
This is a little different. It is just the MTM section of the NX-Otica. The cabinets are unfinished. I mounted the drivers so I can test a pair of NX-Otica crossovers I'm building for a fellow AC'er when I get them done.The wires are there to make it easy to hook to the networks with alligator clips.Mike
Mike,Any progress on the MTM's?Thanks,Ed
