Newbie here, 1st post. I've been looking at this NX-Otica kit for some time now. Planning to purchase first week of July 2021. Before I do, I want to ask if anyone that has built them have any regrets or wish they had chosen a different pair. I appreciate your input.
Newbie here, 1st post. I've been looking at this NX-Otica kit for some time now. Planning to purchase first week of July 2021. Before I do, I want to ask if anyone that has built them have any regrets or wish they had chosen a different pair. I appreciate your input.Bill
... All that remained was to apply grill cloth for the sub grills and assembly the amp boxes. To attach the grill cloth, I used a method found some years ago on the web. Rather than dealing with glue and/or staples, build them like window screens and use a rubber screen spline to secure the cloth. Before painting, I routed a 1/8-inch wide by about 3/16-in deep groove around the perimeter of the grill frame. I purchased 1/8-in black rubber spline from Ace Hardware and used a roller wheel installation tool to set the spline. Started with the short ends and did sides last. Great thing about this method is that you can easily correct mistakes and adjust the cloth tension. Use a single-edge razor blade to trim the excess cloth and your done....
Thought I’d post a picture of my setup, the speakers and subs are about three weeks old. Thanks to everyone on this forum who helped me out.
Hi,I'm new to this forum and from a different continent: Europe.I was wondering if you know if there is any NX-Otica build in Europe ?I would really like to listen to it before orderingThank you.
