Help on service of Cayin500
0 Members and 1 Guest are viewing this topic. Read 1227 times.
Arun Narula
« on: 21 May 2016, 12:49 pm »
Dear Friends :- Need help on a service manual for a cayin 500 that came in for service with two 10 Ohm resistors burnt on the output stage of the amps . would like to replace them but also check the biasing currents after doing so to avoid a repeat of the same
JerryM
  • Where's The Bar?
Re: Help on service of Cayin500
« Reply #1 on: 21 May 2016, 01:54 pm »
Welcome to AudioCircle, Arun.  :beer:
Phil A
« Reply #2 on: 21 May 2016, 01:56 pm »
Welcome to AC!
Phil A
« Reply #3 on: 21 May 2016, 02:02 pm »
I believe the below is the current US Importer (if not in the US, then you'll need to contact someone else) - http://www.usatubeaudio.com/cayin-a88t-mkii.php
Phil A
« Reply #4 on: 21 May 2016, 02:04 pm »
Believe their email is  [email protected]
brooklyn
« Reply #5 on: 21 May 2016, 03:37 pm »
« Reply #6 on: 22 May 2016, 06:47 am »
Service manuals from sino amps are rare on the webb, you dont need a service manual from this amp, unless you can read Cantonese or Mandarim language, as you are in India you need a service shop in you country.
Email the factory here (tech support address) and ask help to service it in your country or yourself that seems is your purpose:
http://en.cayin.cn/contact.asp
Good luck
« Last Edit: 22 May 2016, 08:17 am by FullRangeMan »
