DVD player for CDs, can I get cheap, cheap and cheerful?
0 Members and 1 Guest are viewing this topic. Read 2334 times.
Doublej
New DVD players sell for under $40. Has anyone tired one for use as a CD player? If so how did it sound?
I am currently using an Imac with an Audioquest Dragonfly DAC and am wondering how much better or worse a standalone DVD player would sound for CDs.
srb
Re: DVD player for CDs, can I get cheap, cheap and cheerful?
« Reply #1 on: 16 May 2016, 06:33 pm »
I have two inexpensive DVD players, a Denon and a Yamaha.
Yes it's true that a dedicated CD player with laser optimized for CDs might give a tiny bit better results than a DVD player's laser optimized for DVDs, but I think the player's internal DAC and analog output stage will be the biggest determining factor in sound quality.
For those that have a DAC with S/PDIF digital inputs, the DVD's sound quality will be more similar to the computer source using the player's digital output.  But with a USB-only DAC like the Firefly, I think you'll find that having to use the budget player's internal DAC, the sound quality will likely be a notch below what you're getting now with the iMac > Firefly DAC.
Super Hans
« Reply #2 on: 16 May 2016, 11:55 pm »
I've been wondering the same thing.
I'm thinking of getting a Blu Ray player since I've seen some 24 bit music I like on BR.
« Last Edit: 17 May 2016, 12:05 pm by Super Hans »
Guy 13
« Reply #3 on: 17 May 2016, 12:24 am »
While I was in Montreal last year,
I bought for 50$ (CND) Sony DVD (Only) player
and I played some CDs that I knew very well how they sounded
and of course, they did not sound as good as my Rega Apollo.
One day, I would like to buy the OPPO 95 or 105 so I can get
the best of DVD, Bluray and CDs.
Guy 13
Poultrygeist
« Reply #4 on: 23 May 2016, 11:42 am »
I'd suggest looking for a older CD player using the famous Phillips TDA1541 chip. Very warm and analog sounding which competes with many of the expensive CD players of today.
I have a Rotel RCD-855 which sonically runs neck and neck with my Marantz 8004 playing red book discs. The Marantz is however better with SACD which the Rotel can't play.
Here's a list of players using the TDA1541 DAC chip.
http://www.dutchaudioclassics.nl/Overview-Philips-TDA1541-based-cdplayers/
FWIW I have a highly regarded Audio GD DAC which I use with my iMac but the Marantz playing SACD has superior SQ.
