0 Members and 1 Guest are viewing this topic. Read 8181 times.
You should be able to install using the same master license. Download as trial first then restore. I went from 8.1 to 10 and did just that. No issue. Either way, enjoy.
OK, I'll try it.
The Windows only version is $50 for new users."Purchase Windows only for $49.98 (Works only for Windows)"
This is for v. 20, when you download now, it's for v.22. I could be wrong and it still maybe this price. Regardless, Foobar sounds better for free.
CHANGELOG: 04/29/16: Version 0.9.7 - DoP for ASIO/WASAPI/DS, direct DSD for ASIO removed.
If you have a DSD DAC, install the DSD ASIO components from the Sourceforge pages. Did that for woodsyi and it works well with his EMMLabs DAC2X.If you are running PCM DAC only, the DFF file component does not recognize ISO files. That have to be DFF format to play.
True. And it plays ISO files. I was dreading having to extract DFF or DSF from ISOs. It beats Aries and Aurender in this regard. I think my PC is robust enough that it can handle the extraction as I play the music. I haven't really compared ISO vs. DFF/DSF of the same stereo tracks.
