Audirvana Plus with free 3 months Tidal trial
0 Members and 1 Guest are viewing this topic. Read 1730 times.
Marius
« on: 6 May 2016, 11:00 am »
try Tidal for three months when buying Audirvana Plus http://audirvana.com
nice offer to come with a great product.
Finally i get to test Bryston Tidal beta... hope to see Bryston's logo soon on the supported device page http://tidal.com/nl/download
Marius
Marius
Re: Audirvana Plus with free 3 months Tidal trial
« Reply #1 on: 6 May 2016, 05:44 pm »
if only MM was able to log into Tidal ...
Chris, the Tidal page won't login with my credentials, that work fine on listen.tidal.com :scratch:
Should i do anything special?
(edited /user/tidal/set manually, which does the trick)
Marius
unincognito
    • bryston.com
« Reply #2 on: 6 May 2016, 06:22 pm »
Marius
dunno, perhaps some character in your username or password possibly?
Marius
« Reply #3 on: 6 May 2016, 06:26 pm »
Cant imagine that to be honest, no special characters.
Maybe add blockers prohibiting some functionality? Disconnect seems too save for some MM pages? Still i had it disabled, and the MM interface wouldn't recognize, or save. UI and PW are correct, since saving in tidal.set works.
Marius
