BryFi
0 Members and 1 Guest are viewing this topic. Read 55521 times.
1ZIP
Re: BryFi
« Reply #100 on: 10 Apr 2017, 09:00 pm »
So, what's the status of this heavenly device??
  • The Demo is Everything!
    • http://www.bryston.com
Re: BryFi
« Reply #101 on: 10 Apr 2017, 10:20 pm »
Hi
Started shipping to the dealers last week.  So far so good - lots of backorders to get caught up on.
james
TJ-Sully
Re: BryFi
« Reply #102 on: 25 Apr 2017, 03:00 pm »
James,
I'm looking forward to learning more about BryFi.   But I wanted to follow-up on a discussion I had with Gary at Axpona.   I asked if a BDP-2 and a Pi player could be synched up as a part of a whole house system so the music plays uniformly and timed in synch at all locations similar to having multiple Sonos players.  He indicated that both devices could access the same NAS library, but there would be timing issues and the music would not be in exact synch from room to room.
Would you confirm that?   Perhaps I interpreted Gary response incorrectly.  But if not, I'm hopeful that with what appears to be start of a Bryston whole house system player system, the timing issue for multi-room playback will be a priority to be included.
Nuz1,
to get at your question from another angle...i'd like to share how i've approached the topic, in part:
in system 1, i have BDP-1 and BDA 2 - and use Roon and external hard drive.
I connected a custom length Blue Jean digital coax cable from the coax out on the BDA2.
Then run the coax cable into system 2.
I have the flexibility of using using the bdp-1 from system 1 in system 2.
also, and i can listen to music with both systems running simultaneously - without evident delay.
makes for one very lively place with both systems running together! perfect for making brunch on sunday mornings!  :D
hope this helps.
cheers, TJ
Re: BryFi
« Reply #103 on: 28 Apr 2017, 05:29 pm »
Hi Folks
Link to our new Bryston BryFI product.
http://www.bryston.com/products/speakers/BryFi.html
james
catmonv
Re: BryFi
« Reply #104 on: 29 Apr 2017, 01:48 pm »
How much does this unit cost?
Re: BryFi
« Reply #105 on: 29 Apr 2017, 02:13 pm »
Hi
$1495 List.
Its a bargain when you consider it's a pair of Mini A's (which sell for $1400 on there own) and the BryFi has a full set of Mini A's, A 150 watt amplifier and a Raspberry Pi computer built in.
james
Re: BryFi
« Reply #106 on: 9 May 2017, 05:29 pm »
Hi Bryston Folks
We received the BryFi‘s ...  fantastic units!
The white one looks great and we received very good feedback already from dealer, who visited us in our office.
Gilberto
MGM Audio AG
Switzerland
Re: BryFi
« Reply #107 on: 16 Jun 2017, 02:57 pm »
SUBJECT: Bryston BryFi Wireless Audio System
June, 2017
Hi James,
Tried the new Bryston BryFi wireless audio system .
It sounded excellent, even on Radio!
One of the best sounds we have heard from an "all in one box type" device.
Well done
James Tan,
AV Design, Malaysia
Re: BryFi
« Reply #108 on: 20 Jun 2017, 06:57 pm »
Hi Folks,
BryFi now on the website.
http://bryston.com/products/speakers/BryFi.html
James
Re: BryFi
« Reply #109 on: 28 Jul 2017, 02:34 pm »
Hi Folks,
Have a terrific review coming out on the BryFi from Soundstage Magazine on August 1st.
james
1ZIP
Re: BryFi
« Reply #110 on: 29 Jul 2017, 06:02 am »
James;
Are they still back ordered?  If so what is the wait time?
Re: BryFi
« Reply #111 on: 29 Jul 2017, 06:33 am »
James;
Hi
Depending on top cover selection about 2 weeks.
james
srb
Re: BryFi
« Reply #112 on: 29 Jul 2017, 07:01 am »
If the Mini A is capable of 100dB SPL, how is the BW-1 capable of 115dB?  I know the 100dB spec is for one speaker, and a pair might likely measure between +3dB to +6dB more, depending on the distance between them.
And perhaps the BW-1 might measure closer to the +6dB increase because of the close proximity between channels, but still, 115dB seems like an enormous increase.  This doesn't even take into account the limitations of the 75W/ch amplification and what power might actually be required for such a high SPL output.
Re: BryFi
« Reply #113 on: 29 Jul 2017, 10:32 am »
Hi Steve
I will ask the engineering types.
james
Re: BryFi
« Reply #114 on: 1 Aug 2017, 10:51 am »
SUBJECT:  Bryston BW-1 Review – Soundstage Magazine
August 2017
Hi Folks,
Please see the link below – a review of the Bryston BryFi BW-1 Wi-Fi portable speaker system from Soundstage Magazine.
Favourite Quote:
“Bryston’s BryFi BW-1 all-in-one speaker really does approach the sound quality of a system of separates.  I felt there was nothing compromised about its sound.”
This was the primary goal of the Bryston BryFi system … state of the art audio in a portable wireless all in one package.
Full Review:
http://www.soundstagesimplifi.com/index.php/equipment-reviews/18
Pundamilia
Re: BryFi
« Reply #115 on: 1 Aug 2017, 02:25 pm »
It would be very interesting if one of the reviewers out there did a side-by-side comparison of the BryFi and the AxiomAir.
Re: BryFi
« Reply #116 on: 1 Aug 2017, 03:28 pm »
Hi
The Axiom Air uses a much smaller 2 way speaker, different crossover and different software.
james
Pundamilia
Re: BryFi
« Reply #117 on: 1 Aug 2017, 04:00 pm »
Thanks, James.
In doing a cursory comparison, I did notice the difference between the 2-way speakers used in the AxiomAir and the 3-way in the BryFi, but the other differences were not evident.
Thank you for the clarification.
1ZIP
Re: BryFi
« Reply #118 on: 1 Aug 2017, 05:43 pm »
James;
A brushed aluminum Bryston Logo is an extra??
Re: BryFi
« Reply #119 on: 1 Aug 2017, 06:23 pm »
James;
Hi
Yes its a $25.00 extra - its a Black aluminium top with and embossed Bryston Logo
james
