The Megaliths open baffle line array speakers
AUDFILE74
Re: The Megaliths open baffle line array speakers
« Reply #280 on: 29 Dec 2018, 01:02 am »
Amazing  work HAL !!!
wshuff
« Reply #281 on: 29 Dec 2018, 01:33 am »
This is the kind of insanity I can get behind!
HAL
« Reply #282 on: 29 Dec 2018, 01:44 am »
Fun speakers to listen for music.
HAL
« Reply #283 on: 22 Jan 2019, 11:00 pm »
Avoosl came over today to help with The Megaliths moving to a new location in the listening room.
The prototype MS-5 Music Server is up and running with the dspMusikLCD 2x16 system.
Next step is to install the modified ribbon tweeters and wire them up.   Then to get it all hooked up and running and try a new crossover idea.
HAL
« Reply #284 on: 27 Mar 2019, 06:07 pm »
The 8 updated GT Audio Works ribbons are installed and running in The Megaliths.  Making music at this time.
Now for some new measurements to check the dspMusikLCD 2x16 digital crossover with the change to the ribbons.  Tweaking the new positions as well.
« Reply #285 on: 27 Mar 2019, 06:19 pm »
That's gotta sound ridiculously good.
KLH007
« Reply #286 on: 27 Mar 2019, 07:28 pm »
Rich, Let me and Jim G know when it's time to take a road trip down to hear them!
Angaria
« Reply #287 on: 27 Mar 2019, 07:50 pm »
Can you say way has changed in terms of materials or sound of the new tweeters?  Curious if you've compared to the neo3.
HAL
« Reply #288 on: 27 Mar 2019, 11:19 pm »
Tyson,
Just had a friend over that had not heard them in awhile.  Played a live grand piano recording and it has the same large scale sound of the Steinway D.  Effortless is a good description.
Having a digital crossover of this quality with this setup just does things very well.  Full control over everything right from the computer playing music.
I think it will continue to improve as more measurements and adjustments are made as the new ribbons break-in.
HAL
« Reply #289 on: 27 Mar 2019, 11:21 pm »
Kemper,
Will be available after AXPONA if you both have time in April.  Let me know dates and can arrange listening time.
HAL
« Reply #290 on: 27 Mar 2019, 11:26 pm »
The new ribbons are Greg's latest design material.  The internal connection scheme has also been updated.
I have the BG Neo3-PDR's in The Monoliths setup in the other listening room.   Need more time with the new ribbons to see what happens.  Best I can say now is I like them both a lot.
HAL
« Reply #291 on: 2 Apr 2019, 09:55 pm »
Measurements on The Megaliths is done and the dspMusikLCD 2x16 digital crossover is updated. Ran MathAudio RoomEQ on the new HAL MS-5 Music Server and created a new room EQ that sound very good in this setup.
Listening sessions are available by appointment for anyone wanting to hear either The Megaliths or The Monoliths systems. Please PM me for setting up a time.
HAL
« Reply #292 on: 10 Jul 2019, 01:44 am »
Just letting folks know The Megaliths are fully operational since some have asked about a listening session.
PM me for scheduling a demo.
HAL
« Reply #293 on: 12 Aug 2019, 01:09 am »
Doing some comparison testing with a pair of HX300-12OB servo amps compared to the HX800-XLR3 servo amps on the 6x12's.
Having the ability to set the Fc on the servo amp to the crossover frequency above 120Hz will give some extra adjustment range that has proven to work well with The Monoliths speakers.
emailtim
« Reply #294 on: 17 Aug 2019, 05:23 am »
@HAL,
What are your XO points/slopes between the NEO10's and ribbon tweeters ???
TIA
HAL
« Reply #295 on: 17 Aug 2019, 10:48 am »
emailtim,
PM sent with info.
iFi David
  • iFi audio NEO Stream is here!
    • iFi audio
« Reply #296 on: 17 Aug 2019, 07:45 pm »
@HAL
Very insane, but also very cool project. Keep going!
HAL
« Reply #297 on: 17 Aug 2019, 07:53 pm »
Just waiting on the next generation of DSP crossover to try out with them.   That should be fun! :D
HAL
« Reply #298 on: 1 Sep 2019, 12:41 pm »
New batch of HX300 flat pack amp boxes arrived from captainhemo.
First pair glued up. Second pair for later use.
« Reply #299 on: 3 Sep 2019, 04:45 am »
glad they glued up nice for you  Rich.
Now we need to get  you  into some  composite cabs for the  Megaliths and sve you  some  drilling   on the  next pair  ,  looked painful buddy  :LOL:
jay
