L5/G4 Rectifier Question
0 Members and 1 Guest are viewing this topic. Read 2094 times.
chcmuzza
« on: 29 Apr 2016, 03:54 am »
Hi
I've installed a couple of Bendix 5852's into my L5. They seems are running hotter than the Sylvania 6X5GT's (hand on the enclosure test) they replaced but changed the sound for the better.
I have read they require twice the current for the heater, and there has been a suggestion they are not recommended by Lukasz.
Are they OK to use or are there other options I should consider?
Murray
