0 Members and 1 Guest are viewing this topic. Read 16263 times.
By the way I never read your post specifically so I can't say that this was pointed at the "Neutral" cable argument. I agree with that. Warm cables are sometimes even worse than "hyper" cables depending on the situation. But what I was illustrating is who can prove what "Neutral" even really is? Only one cable I can think of that carries the name Cardas Neutral Does it mean it really will sound smooth in every system... Honestly no idea! I can say I had some Cardas Reference top of the line cables at one time. They were actually VERY forward, and a bit to analytical. But I have also had Cardas Golden Cross which were hot for a long time due to being "Warmer" and they were, but they were also sometimes mushy, and boring in many cases which brings us back to the point. What can be proven as neutral in every case? Fact is of the Reference, and Golden cross both were also substituted in the same exact system showing these results! Of course at the time the Neutrals did not exist yet I believe, but I never got that far anyway
Again I am not disagreeing, however man that's a lot of variables to say that a cable is dead neutral no matter what. I mean is there a certain "inductance vs. length vs. resistance vs. capacitance vs. metal" formula used to know who is truly carrying the neutral signal? If your running a lush 300 b tube amp vs. a Class D amp will it send the same neutral signal negating all other laws of audio? If you have a 100 db efficient speaker vs. a 86 db speaker is that cable still neutral in both systems? Again I don't argue at all the fact cables can totally change the sound of a system, and some just will not work, but I have also heard the best cables one day of the week when I measured the AC coming in around 119 volts which is close to the 115 volts most power supplies are designed around, and then plugged this same system into a AC putting out 127 volts, and guess what Neutral was out the window! Weaker bass with such high voltage, much sharper sound, more noise etc... I am just saying that all conditions out there will not allow for a one and only NEUTRAL cable period... Sorry. Some are better, some are worse, but no way we can pin this debate down overall.
Okay... Not to hijack this thread, but interestingly enough I am in the market for a good 12 to 15 foot pair of RCA terminated for a tube pre to a SS amp. Are these fully shielded? I have learned from some risks in the past "Bypassing" a shield especially in something longer like this is not always a great idea. Mainly I am asking because your website is blocked on my end right now from our proxy server. If interested in the Pepsi challenge you can shot me a PM or email with your thoughts, and a price in mind. Thanks
...who can prove what "Neutral" even really is?
After you've done a lot of testing neutral becomes obvious, if that's really your goal. It's not everyone's goal, that's for sure, and that's ok... But it is MY goal and that's how I build my cables. If you like other than that there may be other cables more suitable but for neutral and resolving it'll be very difficult to beat my cables at any price. Quote from: DaveC113 on 10 Jun 2016, 03:11 pm
In the end point is trying to be a purist in the business is really just a path to utopia that does not exist.
You don't need a perfect room or system, which is great since it doesn't exist, but you do need it to be able to reach a certain level of performance described in my last post. Also, speakers with a narrower dispersion pattern provide more direct vs reflected sound and remove the dependency on the room to a large degree, I do this too. My own system is Sony HAP-Z1ES source, a preamp based on Tortuga LDR and Aikido tube buffer:
This was exactly my point... There is no such thing as a perfect room, component, or cable... BUT there is a such thing as a "Reference" point all things would then be measured from to show the change if any. So I was not exactly expecting a valid answer on this as some type of "Black or White" decision.That was all I am illustrating, and look I realize marketing audio products are a whole other world, some hyperbole, and some science to get people to bite. I was again just saying I have probably had every combination of serious gear on the planet, and sometimes the less money spent the better off you are. In this case a lot of the time I see people wanting to spend thousands on a cable because it has 5 dollars of silver in it. Guess what 99% of the time they just believe they are getting something that cannot be achieved otherwise in which a lot of the time it easily can be done another way.
