0 Members and 1 Guest are viewing this topic. Read 7064 times.
Read this and let us know if you have any questions. If you built up computers in the past, I would say you are almost over qualified for the task http://www.computeraudiophile.com/content/638-geek-speak-raspberry-pi-hifi-here/Some of the dedicated streamer might be better, but the value you get for the pi is unbeatable. Btw here's a writeup on chromecast: http://www.computeraudiophile.com/content/677-basic-bit-perfect-testing-35-chromecast-audio/
Don't forget to get an extra external backup drive or two. It's going to take a while to back it all up and if you lose it, it's a real pain.
+1000. Best advice so far in the thread
Best Buy has an Asus laptop on sale this weekend.http://www.bestbuy.com/site/asus-15-6-laptop-intel-celeron-4gb-memory-500gb-hard-drive-chocolate-black/4831400.p?id=bb4831400&skuId=4831400Any thoughts?I've never been a huge fan of Celeron processors, but for something that will only be dedicated to the audio task it may be enough.I plan on loading it up with FLACS (or other file type) and connecting to my DAC with USB. Will also use it for streaming Pandora, maybe Tidal.On a side note, I picked up a Google Chromecast Audio to play with to give me a temporary solution.
Forgot to mentioned that the most important thing of all is make sure you pick a hardware platform that supports a user-interface that you can live with. Afterall, the interface (JRIVER, mpd client, HQ player, roon, foobar or whatever you may prefer) is what you will use all the time so it's important to make sure you really really like it. Nothing worse than trying to play some music and it's too cumbersome to use or the software have many bugs. So I really recommend to take a look at the suggestions in the thread and other you consider and and make sure your preferred player will be supported and user-friendly before determining what to get.90% of the time I would pick a system that is easy to use and the whole family can envoy it over a complicated but perfect hardware/software set-up
Another bad idea. If you like your sources with a big dose of noise go right ahead. If you can't fork out the $500 or so for something new like a Auralic Mini or Bluesound Node, even a used squeezebox or Mac mini would be preferable.
Noob question here Jon, why is a laptop noisy and a Mac Mini not? And what advantages does something like an Auralic Mini have over both of those?
