Bryston Turntable
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Turntable
« Reply #220 on: 14 Oct 2016, 01:50 pm »
Hi James
Some iPhone photos of the BLP-1 at the new London hi-do show.
Going down very well!
Really nice turntable James
Regards
Peter Thomas
PMC
Vipers
« Reply #221 on: 15 Oct 2016, 08:53 am »
Had a good listen to this yesterday at the Indulgence show, very impressed, I have to admit I was a little surprised when Bryston announced a turntable but I shouldn't have been as yet again Bryston have delivered the goods, nice organic sound but with excellent detail.
I'm going to get one for demo so that I can have a proper listen outside of a show environment, but after the show I can't wait to get one, just need to figure out what cartridge to use :-)
saveloy
« Reply #222 on: 15 Oct 2016, 07:34 pm »
Had a listen today at the Inulgence Show.  And it sounded lovely.
It was one of 2 highlights of the day; the other was the VPI Signature turntable.
Well done, James.
Kyri
« Reply #223 on: 15 Oct 2016, 08:06 pm »
Well done, James.
Kyri
Thanks - so far the response has been terrific  :thumb:
james
saveloy
« Reply #224 on: 15 Oct 2016, 08:19 pm »
PMC are running with an Ortofon Cadenza Black cartridge.  It sounded like warm, lush vinyl to me.  And it was obvious I was definitely not listening to digital audio.
Kyri
CanadianMaestro
« Reply #225 on: 16 Oct 2016, 12:01 am »
Kyri
Both have their strengths/weaknesses, but when digital is done right, like with BDP-1 and BDA-1 (and other gear), distinguishing between analog and digital is hard with the best recordings.
abuhannibal
« Reply #226 on: 16 Oct 2016, 05:32 am »
James,
I know I said I had asked my last question but I realized I have one more.  :)  Can you tell me how high the bottom of the plinth (and also the motor pod) is from the surface the table sits on? I ask (in case you're wondering :)) because I have cats and will want to stick something underneath the rear, like maybe a hockey puck or two, to keep the little critters from tipping the table if they go on it.
Just getting my ducks in a row before delivery.  Look for my review in mid-December....
« Reply #227 on: 16 Oct 2016, 10:56 am »
James,
Hi
1 3/4 inches from the bottom of the plinth to the shelf the table sits on and about 1/2 inch of clearance from the bottom of the bearing housing and 1 inch from the motor pod.  The table has a 3 point suspension  - 2 feet at the front and 1 at the back middle so not easy to tip a tripod.
james
abuhannibal
« Reply #228 on: 16 Oct 2016, 11:29 am »
Thanks. Yeah I know, but I will stick a hockey puck or some soft piece of rubber under the relevant spots just in case. As fundamental forces of physics go, the cat-turntable attraction is nearly as strong as the infamous cat-keyboard attraction.  :)
Anyway, really looking forward to hearing this in my system!!
« Reply #229 on: 17 Oct 2016, 01:45 pm »
Hi James,
Just connected the new phono...and its absolutely superb out of the box !
Beautiful tonal balance and a level of detail and depth which i never experienced before...now i know what i missed all these years..
Cheers to you !
Tom
Samurai7595
« Reply #230 on: 17 Oct 2016, 05:28 pm »
James, any recommendations for cartridges for the Bryston turntable (i.e. carts that have been tested by Bryston)?
« Reply #231 on: 17 Oct 2016, 05:40 pm »
I like the Ortofon Black MM and the Denon 103D MC as well as the MC Gliders form Benz and MC's from Ortofon so far.
A number of our customers have emailed me though and some are using cartridges that cost more than the turntable! ... with good results.
The tonearm has a mass of 10 grams so it ill work well with a large variety of cartridges.
james
abuhannibal
« Reply #232 on: 21 Oct 2016, 02:08 pm »
James,
One small point of clarification - is the tonearm connector a standard 5-pin DIN or one of the Goldnote 4-pin connectors? Not a big deal but I have a Siltech phono cable I might want to try (which currently is terminated in a standard 5-pin DIN.)
« Reply #233 on: 21 Oct 2016, 04:31 pm »
James,
It's the 4 PIN DIN.  We will have an adapter to allow for 5 pin going forward.
james
« Reply #234 on: 21 Oct 2016, 04:34 pm »
SUBJECT: Bryston Turntable – Swiss Audio Show
Hi James
Some comments on the new Bryston Turntable at our recent audio show in Switzerland.
The show went very well. I think we had one of the best performance of products, room acoustics and demonstration. And now one step more with Bryston Vinyl.
Here a short statement from our dealer handling the show with us.
Ok the Bryston BLP1 turntable, first thoughts.
I found it to be of good build and up to Bryston quality, after unpacking and fitting a Kiseki Purple Heart I was instantly enthralled at the wonderful full rich soundstage that greeted me, instruments were correctly placed with a  full open timbre and sense of timing, as were the vocals. The BLP1 played everything with ease from classical to pop to rock.
I can easily recommend this to my clients and customers as well as live easily with it myself ... a stunning effort for Brystons first turntable ... a classic!
Warmest regards
Foxx Artizan Delaney
Artizan Audio GmbH
Well done, James,
Gilberto Giacon, MGM.
abuhannibal
« Reply #235 on: 22 Oct 2016, 04:06 pm »
james
Thanks. Just wanted to mention for the assembled multitudes that Akamai sells the 4-pin DIN connectors, so one can re-terminate existing cables, and also this, if you want to use their arms with RCA cables: http://www.akamaiaudio.it/index.php?id_product=273&controller=product&search_query=rca&results=10
« Reply #236 on: 22 Oct 2016, 04:56 pm »
Hi
Yes thanks I was aware of that and when I discussed it with Goldnote they said that the 4-pin is the DIN standard and the 5 Pin was introduced by SME and some aftermarket cable companies have both some only 5 pin.  I am playing around now with a custom silver 4 pin din cable to see if I hear a difference.
james
abuhannibal
« Reply #237 on: 22 Oct 2016, 05:02 pm »
OK. FWIW I am not in a rush to change the supplied cable; it's just that I do have that Siltech, which I know to sound great, so it might be nice to be able to try it. Not at all a huge issue for me though, I assume the supplied cable does not suck.  :)
« Reply #238 on: 24 Oct 2016, 04:05 pm »
Hi James
Kiseki Purple Heart,an excellent partner to the Bryston BLP1 turntable - looking forward to auditioning for our clients.
abuhannibal
« Reply #239 on: 25 Oct 2016, 07:53 pm »
Hi
james
So it seems. I ended up deciding to order a cable with that connector from Audio Sensibility, just b/c I happened to be able to find a bit more $$ in my budget and couldn't think of anything else I needed to buy at the moment. :) Will report here on sonic differences between that cable and the stock one, though that will take a good six weeks until the table and cable and I are all together.
