0 Members and 1 Guest are viewing this topic. Read 20187 times.
Please list what else is in your system. And specifically power treatment?
Thanks Jim.I removed the cage and noticed the three dials, but have not touched any of them after reading the disclaimer that came with the speakers. I will try tinkering with the gain setting tonight.Out of curiosity, would the phase and crossover settings be the same for every Exotica 3?And before shipping an Exotica 3, perhaps marker settings showing the reference points around the phase crossover section of the dials be helpful in case someone accidentally moves a dial, or has little kids around?I will also move the power cable that is going to the subwoofer off of the AC filter as it was previously suggested to see if there is an improvement.
Yes, the gain is the only thing you want to deal with.As to whether or not the settings are the same for every Exotica 3, I don't know. You can't assume every driver and every amp will perform exactly the same. And the controls might vary in terms of performance as well. So we calibrate each pair before it ships.Marking them is probably a good idea, although we would have to find a very fine marking pen.- Jim
Jim should not put a disclaimer in the back that scares folks from touching the gain setting on the amp. With all kinds of amps/preams/processors/receivers out there with myriads of variable impedance matches even before considering room interaction, there is no freaking way Jim can dial in the woofers for his customers without going out on location because he doesn't know how your amp drives the mids and highs. You need to level match the sections after you receive the E3s. I don't have the E3s but I have an active system and I tweak the balance for different genres of music for god's sake -- different compression scheme between rock and classical recordings. I encourage you to play with the knobs.
You probably won't be able to hear the difference as long as you get it back real close to the location. Even if it was off by a 1/16th an inch you may not be able to tell by ear. I wouldn't touch anything but gain.However I sincerely doubt the gain is the problem. The only thing that would make sense for that is if the room somehow was gobbling up the bass frequencies.
