Anyone have an all-electric car?
ctviggen
« on: 11 Apr 2016, 03:45 pm »
Anyone have a true electric car (not the Chevy Volt, which has an engine that can charge the batteries, and not the Tesla, which I don't think is affordable for 99.99999% of the population)?  If so, how do you use it?  What's the trip distance to/from work?  Do you take it out on weekends?
Since my wife is (one of these days) getting a 7/8 passenger vehicle, I started looking into electric cars for my car.  However, I have the following issues with them:
1)  They're really expensive, even with the rebates/tax refunds.  And the tax refund is only a refund, meaning that you'd have to put up the money until you get the money back in taxes.
2)  They have a (listed) range of maybe 80 miles.
3)  The actual range (as tested by car mags) is much less, by almost 20 miles.  Furthermore, that's on a good day when it's not cold and you're not running the heater and heated seats.  When it's brutally cold outside, you'll be lucky to make it forty miles.
4)  As far as I can tell, they're basically a car to go to and from work, and that's about it. They're not really a second car.  In other words, if you want to go on a 2-3 hour trip for a weekend get-away, you can't take that car.  Which means that if you have a family, you're putting all the mileage on the 7/8 passenger vehicle, which gets terrible gas mileage, and little to none on the car that gets great gas mileage.
5)  There are no charging stations anywhere.  For instance, where I work, there's one charging station in that town, and it's nowhere close to where I actually work.
6)  Many of the cars don't support fast charging (as popularized by Tesla), which means it takes hours to charge your car.
So, does anybody here have an all-electric car?  If so, how do you use it?  Would you disagree with anything I said above?  If so, what?
macrojack
Re: Anyone have an all-electric car?
« Reply #1 on: 11 Apr 2016, 04:38 pm »
I don't have an electric car even though I would really like to. I have a 2006 Prius and I only buy about 90 gallons of gas a year between it and my seldom used '97 Tacoma. I also have learned that I overbought on my solar panels. Naturally it seemed like an obvious choice to use my excess electricity (prepaid for life) rather than buying petroleum but, try as I may, I could not find a way to justify the expenditure.
For you, however, the new Tesla 3 ($35,000) or the upcoming Chevy Bolt ($37,500) are a couple of options to explore. Both are expected to deliver over 200 miles per charge. It is also a good idea to look into your state's laws concerning electric cars. Here in Colorado there is an interesting loophole whereby you can buy a used electric vehicle fro out of state and still get the original tax consideration. It is called a credit but they pay it to you directly, even if you don't have any tax liability. The only catch is the car must not have been registered in Colorado previously. I considered buying a LEAF from out of state and having it trailered back here. Those cars can be had for as little as $8000 and the tax rebate is around $2500 to $3000.
In the end, you have to look at how much it costs to save money unless you simply want to do the right thing by lightening your carbon damage. That's a personal decision, of course. Obviously I chose the path that best suited my economics. Since I'm retired and my wife is counting the days until she can join me, we are squeezing our pennies. No electric car for us for the foreseeable future. At the rate we are driving the Prius will probably outlive us.
ctviggen
« Reply #2 on: 11 Apr 2016, 04:55 pm »
Unfortunately, I won't be in the market for a car by the time either of those get here. I did read an interesting comparison of the Chevy Volt and the Prius, and the impression I got was that if you use the Volt's gas engine (to charge the batteries), the Prius works out to be a better value, having cheaper over-all costs.  If you can use just electric for the Volt, though, then the Volt is a better deal.
I could still look into the Prius (and similar gas/electric engine cars), but I really need to figure out what I want in a second car.  I keep thinking I'd like the second car to take some load off the main car, which means being able to take shorter trips with stuff for four people.  Currently, I use my VW Jetta Diesel wagon for that, but we see how that turned out.  I'll have to see what I can fit into a Prius and get the wife to test drive one with me.
As for solar panels, I also installed these on my home and I don't know how good they are.  The electric company keeps raising rates (if I produce more than I use, I still pay $19/month).  I don't mind paying fees if I produce more than I use, as the company still has to maintain all the lines. However, in Arizona, what they did was when you produce more than you use, the company pays one rate (say 5 cents/kwHr), but when you use more than you produce, the company makes you pay a second rate (say, 10 cents/kwHr).  The way I pay, those are the same rates (that is, the rate I pay when I take energy from the grid is the same as the rate I pay when I put energy on the grid).  If my state changes this to the Arizona model, my solar panels will be a waste.  We'll have to see what happens.
sts9fan
« Reply #3 on: 11 Apr 2016, 05:00 pm »
I have had a Nissan Leaf for the last two years and it is my favorite car I have ever owned.  Obviously Im not a car guy and have little to no use for BMWs and the like.
1) you can be in a Leaf for under $25k
2) and 3) I driver mine every work day and with the heat on you will ALWAYS get over 60miles.  Im not sure where you got that 40 mile number.  The biggest difference in range is when driving 60mph on the freeway vs side roads.  While it is satisfying on the freeway the range is diminished.
4)  We drive our Leaf 90% of the time even on weekends.  Sure if you are driving a few hours away then its no good but overtime you are home you are charging so its not a "per day" range.  You could drive 60 miles in the morning and be fully charged in two hours.
5)  In two years I have never charged anywhere but home.  I think my all in delivered eclectic rate is ~$0.18/kWh and most charging stations are $0.5/kWh.  How far do you work?  Why do you need to charge when out?
6) I know my Leaf has a fast DC fast charge socket but the stations are not available.
I love my car.  Its truly great to never go to a gas station and I have never ran out of charge.  Let me know if you have any other questions.
How often do you drive over 60miles in a day?
S Clark
« Reply #4 on: 11 Apr 2016, 06:11 pm »
Nearly every time I drive, since I live 22 miles from the edge of town and the nearest grocery store, restaurant, etc. are a few miles in.   Does that mean that us rural folks shouldn't sign up for the latest Tesla?
ctviggen
« Reply #5 on: 11 Apr 2016, 07:24 pm »
The Leaf is one car I would be looking at.  I usually drive to and from work, about 40 miles total.  My wife is adamant, though, that I would have to be able to pick up one or both kids, should I need to do so, which will add at least 10-15 more miles, and may add more.
As for the 40 mile range, that's an estimate because the batteries are worse in the cold and would have to run a heater and heated seats.  See:
http://www.plugincars.com/reduced-ranges-electric-cars-cold-129205.html
"Yes, I have personally experienced a 20 percent drop in range, between driving a Nissan LEAF along the Mediterranean Sea, and an identical LEAF in Oslo. The car tested in the south was on summer tires, while the one driven in the north had winter tires. This alone can reduce range by 10 percent considering most EVs are sold with special low rolling resistance tires (in Europe). Of course, I had the heater on when driving in Norway. The temperature was about zero degrees Celsius."
So, I guess electric cars are really to and from work cars, until they get up to 200+ miles.
ctviggen
« Reply #6 on: 11 Apr 2016, 07:26 pm »
Personally, I can't tell what I think about spending 70k for an electric car.  Certainly, you can't be looking for reduced cost, as you wouldn't get that money back over many decades.  So, I don't know why people buy a Tesla.
Phil A
« Reply #7 on: 11 Apr 2016, 07:48 pm »
Until there are more charging stations, a drop better range and the price starts to get a bit more competitive, I don't think they are quite ready for prime time.  I have solar panels integrated into the roof tiles (and if I shut off the pool pump running for 8 hrs./day it would probably be negligible monthly costs if anything).  I put several circuits in the garage (I have 300 amp electrical service, 50 amps for the audio system and have an extra three circuits in the garage each with 2 receptacles) in case I ever consider one.  I went with an electric golf cart as a second car and on some occasions, I use it to got to the local shopping center for lunch.
sts9fan
« Reply #8 on: 11 Apr 2016, 09:47 pm »
In my personal first hand experience I would feel comfortable getting 60mile range 365 days here in MA. Absolutely 100%.
SClark: I have two kids and a wife. Does that mean I should not only have two seat sports cars?? YMMV
As for prime time, some folks won't be willing to convert. For the most part range issues are in people's heads.
People get hung up on charging stations. In most cities they are everywhere. That said most EV owners don't use them. What's the point paying 2x to get 15min of juice at the grocery? It's pointless.
MtnHam
  • SoundLab and Fritz Speakers Dealer
« Reply #9 on: 12 Apr 2016, 05:37 am »
Having had a dealer loan for 24 hours, I can say that the Tesla S is a fabulous luxury car which compares well with other cars in it's price class. A 250 miles range is very adequate for most driver's needs. When the 200 mile, $35,000 Model 3 really becomes available, it will be a game changer. The huge advance sales clearly speak to the pent up demand. The other major auto makers will be there too.
In the meantime, my ebike gets a lot of use. It's terrific!
« Last Edit: 12 Apr 2016, 07:07 pm by MtnHam »
avahifi
    • http://www.avahifi.com
time to talk about the Tesla Model 3 again.
« Reply #10 on: 15 Feb 2019, 08:30 pm »
There are now nearly 200,000 of these on the road now.
The long range dual motor version has 310 miles range and with a network of fast charging stations over much of the USA now range anxiety is pretty well eliminated.
The cost of the AWD model is now under $50,000 and it is amazing to drive.  Rear wheel only model with 240 mile range is $42,000.
These are rated the safest cars made right now.
Must be a member or two out there that now owns one.  I am thinking about one this spring.
Frank
MtnHam
« Reply #11 on: 15 Feb 2019, 08:53 pm »
The Tesla 3, Chevrolet Bolt, and the Nissan Lief are now proven successes. 2019 and 2020 will see the introduction of many more choices, all with considerable range, from major manufactures. The day of the pure electric car is here! Without a doubt, my next car will be an EV. And, my existing solar system at my home will provide the power.
audioengr
« Reply #12 on: 15 Feb 2019, 09:22 pm »
I don't think you get the significance of an electric car.  You don't look for charging stations like gas stations.  You charge it at home for all of your local commuting. It's only when you take a long trip that you need charging stations.  I took a trip to San Diego and used lots of charging stations along the way.  You need a potty break or food anyway and you need to stretch your legs.
There is NOTHING out there like a Tesla, at least yet. They are the only car with a long-range charging infrastructure already in place, for the US and Canada.  My models S charges to almost 300 miles at a DC Supercharger when travelling.  For local, I use a "destination charger", which is AC at my home.  It charges about a mile a minute.  The Supercharger charges about 3-5 miles/minute.
Inexpensive Model 3 is due out this year.  The current model averages about $50K with 320 miles range and 4-wheel drive.  The inexpensive one is alleged to cost less than the average car cost in the US, which is $36K. You will save on average $50/month doing the same driving because it gets such good mileage.
Steve N.
guf
« Reply #13 on: 16 Feb 2019, 12:22 am »
I had the electric Fiat for three years. then I had a BMW i3 for two years And now I'm waiting for the "cheap" Tesla. 98% of the time I charged my car at home. Occasionally I would  park and charge just because it was a better spot but here in California there's so many electric cars gone are the days of getting a primum parking spot. Others are right that said  you don't go out looking for places the charge car. You do all your charging at home. My city is also only 7 mi.² so the range thing was rarely an issue for the last five years. Even when I had a 20 mile each way commute it was never a problem.  In both my cars got about 100 miles per charge.
Both of my cars my monthly payment was cheap.  $212 for the Fiat and The Bmw was 252$.  Both with minimal down payments that the state gave 2500$ back and covered. Most people would say never buy only lease electric cars.  Tesla is changing that by making the lease options horrible.
Peter J
  • Hmmmm
« Reply #14 on: 16 Feb 2019, 02:36 am »
This one's all electric, I think;
Kinda small, but cheap ...
Bizarroterl
« Reply #15 on: 19 Feb 2019, 03:53 pm »
And pink!
rollo
  • Rollo Audio Consulting -
« Reply #16 on: 19 Feb 2019, 04:12 pm »
 A great concept for sure. Would buy one when they put a charger in vehicle. Do not like the idea of charging stations. Why cannot an alternator be used ? Everyone would want one. If and when it would be a Tesla.
charles
Don_S
« Reply #17 on: 19 Feb 2019, 04:20 pm »
A recent Tesla crash in Fremont, California resulted in a car fire and it wasn't a gas tank that exploded. Scary stuff.  :o
https://sanfrancisco.cbslocal.com/2019/02/18/tesla-model-x-crashes-burns-fremont/
https://patch.com/california/fremont/fiery-crash-destroys-tesla-fremont
audioengr
« Reply #18 on: 19 Feb 2019, 05:33 pm »
Tesla is the safest car on the road, period.  Many Tesla head-ons result in the other driver dying and the Tesla driver walking away. Nobody talks about those.  The reason that the very few Tesla incidents are publicized is that the gas car manufacturers and oil companies don't want them on the road.  They are the future, no denying it.
Have you seen the large fire crashes on the highways on the east coast?  Two of them in the last 2 weeks.  Many people injured in other cars nearby.  Gasoline and diesel is much worse because it leaks out and burns you up before you can exit the car.
Steve N.
ricmon
« Reply #19 on: 19 Feb 2019, 08:38 pm »
ctviggen I just like to make one recommendation.  Electric cars have become main stream and are now addressing all of your concerns.  Or put another way there is no good reason not to buy an electric car.  Just find one in your budget.
Ric
