0 Members and 1 Guest are viewing this topic. Read 7303 times.
Another way to check your system if you dont have a source isdisconnect the ic's from the cdp,turn max vol preamp/pwrampand touch the ic with your hand,then put your ear close to speakerand listen for hum/ic noise if you do all is good and the cdp is at faultcheers
I have a simple two channel system consisting of a Virtue Audio Piano M1 cd player, Quad 12L speakers and a BelCanto eVo2i integrated amp. Connectors are all Anti Cable. I hadn't used the system in a while and when I first hooked it up recently music seemed fine. Then one day soon after any cd I played skipped tracks. I had the player checked and my tech found nothing wrong. Today I got around to trying again and there's no sound at all. I checked the connections and that mute wasn't on. Also verified that all the amp's inputs were enabled. I can't figure it out and would be very grateful for suggestions.
WHAT??!!! TURN THE VOLUME CONTROL TO MAXIMUM? MAXIMUM? That not only will possibly blow his speakers but could damage his hearing.Specs on OP's amp. Power output per channel into 8 ohms • 120 watts <1% THD+NPower output per channel into 4 ohms • 200 watts <1% THD+NBandwidth: +/- 3dB •1Hz-80KHz
I agree. Never go Full Volume when troubleshooting!!!
I understand
we get a smart alec like you here from time to time...
Really time to time huh. Last time I checked I have been a member of AC longer than you.I just hope the OP read my response to your idiotic post and didn't try what you suggested. Why would anyone want to deliberately try to blow a guys speakers. Tell you what, why don't you try what you wanted the OP to do on your own audio system. When you try the test make sure you crank the volume control up full bore. Then just to drive your point home touch the center pin of each un-ported IC to get the full affect.Don't forget to put your ear up against the speaker so you will hear it real good. Please post back the results of your unforgettable experience.Best of luck.
you dont understand anything!!!all i'm saying if you play a system with 3v peak,how come a few millivolts peak of noise be harmful??do the maths!!!
The only way one can get a 3v peak is by playing at FULL VOLUME. I have a conservatively rated 280 watt amp. I have 91 decibel speakers. My preamp has 20 dB of gain. My pre probably runs at 2v max out. Do the real world math at that. What does that sound like in my listening space while troubleshooting?? Seriously, never ever ever go full volume when troubleshooting. There's just too many other viable options available that won't blow things up..
