Best wire for interconnect cable up to $12.5/ft.
0 Members and 1 Guest are viewing this topic. Read 1474 times.
rmihai0
« on: 31 Oct 2004, 02:35 pm »
Best of your knowledge, which wire is the best for analog interconnect cables up to $12.5?
Thank you
In my opinion: Alpha Core Goertz Micropurl Silver
Ulas
« Reply #1 on: 31 Oct 2004, 02:47 pm »
Tone arm wire. If it's good enough to get the signal from the cartridge to the DIN plug, it's good enough to go all the way to the preamp. All my ICs are made with Cardas 33awg tone arm wire.
djbnh
« Reply #2 on: 31 Oct 2004, 05:04 pm »
You might want to message Chris VenHaus about his Cotton-Insulated Fine Silver Wire. E-mail for CVH is: [email protected]. From several experiences with Chris, he is great to work with, 100% honest, and has numerour DIY recipes. Best of luck in your quest.  :wink:
