Industry Circles
Empirical Audio
audioengr
Final drive into transformer input
driguy
21 Mar 2016, 12:20 am »
Hello Steve,
Is it possible to use the Final Drive with an amplifier that has a transformer input? In my case it is a Lundahl 1:4 step-up transformer. Thanks in advance for your time.
paul79
Industry Participant
Re: Final drive into transformer input
21 Mar 2016, 01:30 am »
The Final Drive should replace the transformer in the amplifier. 2 signal transformers in the chain would be a bad thing.
audioengr
Facilitator
Reply #2 on:
3 Apr 2016, 05:28 pm »
It will not hurt anything, but it will likely reduce SQ. The SQ of my transformer is much better than the Lundahl and you will not get these benefits with 2 transformers in series.
Steve N.
Industry Circles
Empirical Audio
audioengr
