0 Members and 1 Guest are viewing this topic. Read 8290 times.
I find it has a more robust, deeper kind of flavor. Also not as bitter in comparison to store bought, packaged kinds of coffee available in the US. Have never tried fresh ground, so not comparing to that, just the packaged stuff: Maxwell House, Starbucks, etc., other off the shelf types.
My daily driver is a large Bee House Ceramic Single Cup for my pour over. I use a #4 Melitta filter and couldn't bee happier (sorry, had to do it) It's really hard to to mess up a cup of coffee when using the Bee House. It doesn't take all that long to make. A timer to allow the water to cool the the desired temperature. A pre set setting for my desired grind. A kitchen scale to weigh the beans and water. Are there easier ways to make coffee? There is, but I really enjoy the ritual.Pretty tasty bean water.
So you really weigh while adding water? And I thought I was anal
buy a hand grinder and you can at least grind your own beans.
So is the key with the pour over method having the right amount of coffee beans with the right amount of water? I'm guessing that's why I see a lit of people weighing their coffee.I tried a Chemex pot over the weekend and was making just enough for one cup at a time and thought it tasted just ok. Not nearly as flavorful and full bodied as the aeropress. Or maybe I just prefer the aeropress...
Water to bean ratio is important. I like to experiment. Some coffees i like stronger, so i'll add more grounds. Here are some directions.https://bluebottlecoffee.com/preparation-guides/drip
Thanks. I was also told today that how fast/slow you pour the water has an effect as well.
I think all the weighing and stuff is for nerds. It's not hard to eyeball. Plus you can adjust to taste.
From the blue bottle instructionsStep 7Starting at the bed’s center, gently pour twice the amount of water that you have coffee into your grounds – for example, 50 grams of water if you have 25 grams of coffee. Work your way outward gently, and avoid pouring down the sides of the filter. You’ll notice that adding this amount of water causes the coffee to expand, or “bloom.” Allow it to do so for between 30 and 45 seconds. A solid bloom will ensure even water dispersion – and a delicious cup later on.I've seen many similar instructions elsewhere, don't "drown" the coffee at the beginning, pour enough water to get the grounds wet and then let it bloom.BTW, 50 grams of water is also is 50 ml, so its not that hard to figure out, you don't have to weigh the water. I might have to try being more exact with the water, and see if I can tell the difference.Randy
..... whenever I do go to a coffee shop I always order an espresso rather than their regular coffee.
