Dayens Monoblocks
AvsFan
Re: Dayens Monoblocks
« Reply #40 on: 29 Jun 2021, 03:55 pm »
$1600 vs $650
And YES! A $950 difference? I seriously doubt it.
« Reply #41 on: 29 Jun 2021, 05:57 pm »
Single ended?
Firstwatt SE amps have 1 transistor, PP amps have 2.
The First Watt aré rather expensives, I could take the Ampino, great value at under  $1K.
opnly bafld
« Reply #42 on: 29 Jun 2021, 06:00 pm »
You totally missed the point, I was not recommending FW.
We were discussing se vs pp.
« Reply #43 on: 29 Jun 2021, 06:01 pm »
Alright you two, so your conversation went above my head. LOL  :)
Lets put it in simple terms for a simple man.
In terms of pure sound quality, which amp provides the edge? Monoblocks or stereo Dayens Ampino?
Its all personal taste,  mainly in music a so mutable art.
opnly bafld
« Reply #44 on: 29 Jun 2021, 06:02 pm »
I have a small room, 12x10, have super easy speakers to drive, ZU Audio Omen Dirty Weekends, 12ohm, 97db efficiency. And although I do listen at 97db volume levels at times to some Metallica, I think that 35 watts x 2 per channel will be plenty.
 :thumb:
AvsFan
« Reply #45 on: 29 Jun 2021, 06:18 pm »
:thumb:
Placing an order tomorrow. So will keep you posted.
