Coffee
0 Members and 3 Guests are viewing this topic. Read 74960 times.
Re: Coffee
« Reply #220 on: 12 Apr 2024, 02:58 am »
I have 2 ceramic grinders and 1 steel burr gears and all them do not allow wet the internal parts in the owner manual. I suspect this info about wetting the beans was released in the press to damage the grinders currently in use and create new sales.
Letitroll98
  • Too loud is just right
Re: Coffee
« Reply #221 on: 12 Apr 2024, 10:09 am »
I'm sorry my dear friend, but that's silly, perhaps you were joking.  As noted by others we're adding moisture, not a flood.  What the manual means is don't immerse the grinder, as in don't wash it with water.  Adding a tiny amount of moisture reduces static electricity and as noted may slightly increase flavor.  It won't change your beans, just enhances the brew.  No manufacturers are advising customers to destroy their machines so they can sell new ones.  However as with all things please use your best judgement on wetting beans before grinding.  Hope you have a wonderful day.
Re: Coffee
« Reply #222 on: 12 Apr 2024, 12:08 pm »
Sorry any mishap not intended, I just found this idea unusual. I increase flavor grinder the beans thinner, I dont like clean the gears, it unset all the grinder.
rbbert
Re: Coffee
« Reply #223 on: 12 Apr 2024, 12:26 pm »
It certainly can’t hurt your grinder to try this once or twice.  Coffee beans themselves have moisture content, this only adds a very little more.
Denton J
Re: Coffee
« Reply #224 on: 24 Apr 2024, 10:08 pm »
Iam using the Cerrado Mineiro full bean, medium roast.
https://www.storehousecoffee.com/brazil-coffee.html
My previous favorite the Jumbo Beans was whole destined for export to Honduras and Jamaica by the farmers association due to the high price of commodities on the international market.
I have some of this on the way!
Re: Coffee
« Reply #225 on: 24 Apr 2024, 10:48 pm »
Good luck hope it will please you.
« Last Edit: 25 Apr 2024, 01:13 pm by FullRangeMan »
Re: Coffee
« Reply #226 on: 8 Jan 2026, 12:41 am »
Audiophile coffee at audiophile prices.
https://www.tedweber.com/other-stuff/coffee/
rockadanny
Re: Coffee
« Reply #227 on: 8 Jan 2026, 01:57 am »
As far as adding moisture,  I have been considering trying this.  I've read that you could stick a spoon handle in water, then use that to stir the beans. Not that much water will have adhered to the handle so should not be too much water. Anyone try this?
AllanS
Re: Coffee
« Reply #228 on: 8 Jan 2026, 02:46 am »
The Cheap Audio Man also sells coffee at audiophile prices.  But if I was going to spend that much on coffee I’d rather put a couple of bucks in Randy’s pocket instead of the grocery chain.
https://cheap-audio-man-stuff.myshopify.com/products/cam-coffee-club
Craig Young
Re: Coffee
« Reply #229 on: 8 Jan 2026, 04:46 am »
I watched a guy that roasted his fresh picked beans in a small metal roaster that was completely enclosed with a hollow handle that was large enough to pour the beans into. He used a hand grinder and then brewed his cup, and I think that flavor would probably be the pinnacle for me.
Re: Coffee
« Reply #230 on: 8 Jan 2026, 04:57 am »
I read from a coffee expert that the maximum shelf life of roasted beans is 6 months, after that should be thrown away to prevent drink mold and bad-tasting coffee.
Coffee can have 4 types of fungi, all can cause very serious illnesses.
« Last Edit: 8 Jan 2026, 07:33 am by FullRangeMan »
mresseguie
Re: Coffee
« Reply #231 on: 8 Jan 2026, 06:35 am »
I travel quite a bit, and I seek out good coffee wherever I find myself in need of a cup. I'm often disappointed by the coffee that I buy - yeah, I'm picky as all hell.  :nono:
There's an amazing coffee roaster in ChiangMai, Thailand. https://www.facebook.com/Ristr8to/
There's an excellent family operated roaster in Corvallis called Oregon Coffee & Tea. I typically buy 6 to 8 pounds of whole roasted beans which I take with me to Taiwan....which, of course, means that I run out and have to make do with the local supply.
There have been a couple other shops over the years, but they've closed down.
Craig Young
Re: Coffee
« Reply #232 on: 8 Jan 2026, 08:32 am »
I have been trying the 100% Kona bean and I was surprised by their recommended instructions of using a just opened bag within 2 weeks. Now I have to try and wait for at least one month to see if it will be a very large taste difference.
S Clark
Re: Coffee
« Reply #233 on: 8 Jan 2026, 02:31 pm »
There are so many roasters out there from a few hundred to a thousand bucks that I'm surprised more of you don't buy green coffee.  Green coffee can keep it's flavor profile for a very long time, and roasting means you always have  fresh coffee.
I've been using an older variation of the Behmor roaster for over a decade... does a great job.   https://behmor.com/behmor-2000ab-plus/
newzooreview
Re: Coffee
« Reply #234 on: 8 Jan 2026, 03:13 pm »
Roasting coffee at home is the way to go.
You can get the best coffee in the world for about $9 per pound and roast it to your preference.
Sweet Marias has a constantly rotating selection of beans from all over the world, and the green beans keep for a year or more without diminishing quality.
For the price of a mid-range Schiit preamp, you could get a Behmor drum roaster and be set for years. The Behmor is the size of a toaster oven, and there's very little smoke when roasting to a medium or light roast, and the flavor is better than dark roasts (which I used to like until I realized they burn out the most interesting flavors). I also realized that light and medium roasts are not weak or tea-like: the body of the coffee comes from the beans (and varies among different regions and farms), and it comes from the brewing (French Press giving the most body to the coffee).
Every green bean on Sweet Maria's has a full description of its character and mix of flavors.
You can roast dark roasts in the Behmor as well: it has a catalytic converter to greatly reduce the smoke, so I use mine in the kitchen. For dark roasts, I might put the vent fan on, but it's optional. The house smells great after roasting.
https://www.sweetmarias.com/roasting.html
mick wolfe
Re: Coffee
« Reply #235 on: 8 Jan 2026, 05:29 pm »
I couldn't agree more. I started roasting my own coffee nearly 20 years ago. I buy most of my green beans from a local roaster, but Sweet Maria's is an excellent source as well. As already mentioned, when you do your own roasting, freshness is guaranteed. I use a Kaldi stovetop unit. Started with a couple different Fresh Roast air roasters, but could never get the consistent results the Kaldi delivers.
newzooreview
Re: Coffee
« Reply #236 on: 8 Jan 2026, 06:31 pm »
It looks like I also posted something similar to the thread two years ago!
Although you made the point at the very beginning.
