One should also order the $10 ear pad rings which are a newer and thinner version for the new 560, 400s, 400i, etc. series. These rings prevent the ear pads from spinning, which is a hassle if it's the Focus pads.
Thanks for inform, Hifiman is really a friendly company,These ear pads rings are round? They will fit the round old model velour pads and the HE400 can?
Yes, the ear pad rings are round. They are listed on their retail site for $10.00. They will accept the older pad mounts since they also have 4 tabs.
If you go to the HiFiMan web site and hit products, there’s a button that say’s more reference to the right of the reference products. The box will open and you will see the rest of the product line..
The NightHawk is nothing like the HD650. Check out the many first impressions of the NightHawk - not "soft" or "warm" as much as "dull".
That's the problem many reviews have. The authors have a tendency to write in their own language which us mere mortals have to interpret without a guide. What dries me nuts are all the descriptive terms available.
