0 Members and 1 Guest are viewing this topic. Read 19615 times.
I know its the Sony - will find out which model.james
So James, any pictures yet that you can share or are you still waiting for dress plates?
Dress plates came in today so the CD Player will be on the way to the Montreal show on Monday.james
Who's going to represent Bryston at the show? Audioville?
The ones we use in the BDA-3 DAC - AKM 4490james
Will the user be able to select between the 4 digital filters, or are you going to hard set one of the filters(i hope not).
No we have our own room.james
OK, cause you had mentioned that Bryston would no longer be attending the Montreal show.
James , two more queries... will the current remote work the new player and can the display be turned off like the CD1 ? thanks
Hi James!Any infor on the transport mechanism from engineering? I am interest to know which Sony model it is.Also, are you going to use a larger VFL display like the one on the BDP-1/2?Cheers!Antun
CD only or CD/SACD?
The ones we use in the BDA-3 DAC - AKM 4490James
