0 Members and 1 Guest are viewing this topic. Read 2925 times.
Do you have any experience with contact fluids between tubes and tube sockets for better sound in your Lampi DACs?Can you recommend it? If so, which? If not, why not?Thank youCharlie
Detoxit. That is the link to their vacuum tube cleaning kit. But you can just buy the stuff separately. The kit just had a couple of different concentrations of the stuff and some q-tips/pipe cleaners which you can easily buy yourself.
Naphtha is petroleum ether. Coleman fluid is not. Just a heads-up.
