The OFFICIAL Super-7 thread
0 Members and 2 Guests are viewing this topic. Read 317667 times.
soundofrockets
Re: The OFFICIAL Super-7 thread
« Reply #980 on: 3 Sep 2024, 03:39 am »
PEQ is off.
Rest of the settings are as recommended.
Volume set at 12 o’clock position for now.
They are playing now - testing/tweaking will be later.
I believe I have the RadioShack spl meter somewhere.
What app are you talking about?
I activated the tube section of oppo and ls 100 after long time - there seems to be some hum - it is slowly going away.
soundofrockets
« Reply #981 on: 3 Sep 2024, 03:41 am »
BTW - I am using your Odyssey amps!!
« Reply #982 on: 3 Sep 2024, 03:53 am »
PEQ is off.
Those are nice amps :P
I do 2 things to measure the bass.  First I play pink noise through the system and then I use an FFT or RTA program to measure the full range output.
If you have an iPhone, then the app I like to use is called AudioTools.  You can search and download it from the app store.  After you download it and launch it, there's a bunch of different options for measurements on the main menu - the FFT option is the one you want to select.
soundofrockets
« Reply #983 on: 3 Sep 2024, 03:56 am »
Great - will do that.
So far - I think the bottom is missing and the woofers are not moving!! :scratch: :scratch:
« Reply #984 on: 3 Sep 2024, 04:02 am »
Try switching around the pre-outs from the preamp to make sure the sub is getting a signal.
soundofrockets
« Reply #985 on: 3 Sep 2024, 04:22 am »
The left speaker is not working.   :scratch: :scratch: :scratch:
Only right top section - still no base.
I am using one set of pre outs for speaker section and second set of pre outs for the amp plate.
My brain cannot think anymore.
SoCalWJS
« Reply #986 on: 3 Sep 2024, 01:33 pm »
When I received mine, a connection in the plate amp had come loose causing bass issues. Make sure the wires/connectors in the plate amp are tight.
soundofrockets
« Reply #987 on: 3 Sep 2024, 03:51 pm »
Will take look at the amp boxes.
« Reply #988 on: 3 Sep 2024, 04:25 pm »
If only one panel is playing, try switching the speaker wire so the left amp is hooked up to the right speaker and the right speaker is hooked up to the left amp.
If the left speaker keeps playing and the right speaker does not (ie, no change) then the problem is the speaker.
If the sound switches so the left speaker is not playing but the right speaker is, then the problem is not the speaker.
soundofrockets
« Reply #989 on: 3 Sep 2024, 04:35 pm »
Figured that out - amp was powered off !!!   :duh: :duh: :duh:
soundofrockets
« Reply #990 on: 3 Sep 2024, 04:51 pm »
Amp plate wires look secure.
Perhaps amps are specific for left and right side.
Will switch amps sides and see what happens.
« Reply #991 on: 3 Sep 2024, 06:11 pm »
Are the sub amps on?  The LED should show as green if they are on.
soundofrockets
« Reply #992 on: 3 Sep 2024, 06:36 pm »
Light is green.
Early B.
« Reply #993 on: 3 Sep 2024, 06:40 pm »
It might be helpful to snap a pic of one of the sub amps and post it here so we can see how you got it hooked up and the settings you're using.
« Reply #994 on: 3 Sep 2024, 07:13 pm »
Light is green.
Try hooking up the subs to the main output from your preamp.
soundofrockets
« Reply #995 on: 3 Sep 2024, 07:16 pm »
Here you go.
soundofrockets
« Reply #996 on: 4 Sep 2024, 03:33 am »
Ok - some luck.
Eliminated the pre amp completely.
Using Oppo 205 as DAC and pre-amp - split left and right signal to speaker amp and plate amps.  Everything work fine.  Volume control is through Oppo 205 at 60.
Now need to tweak the volume to optimize listening.
Thank you guys.
SoCalWJS
« Reply #997 on: 4 Sep 2024, 04:20 am »
Ok - some luck.
Thank you guys.
:thumb:
soundofrockets
« Reply #998 on: 4 Sep 2024, 04:26 am »
Wonder what is wrong with LS 100?  Or is it?  Maybe user issue!!!
charmerci
« Reply #999 on: 4 Sep 2024, 03:26 pm »
First going backwards or forwards, switch wires/connectors left to right to isolate component.
