BDP pi
0 Members and 2 Guests are viewing this topic. Read 79964 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP pi
« Reply #100 on: 14 Mar 2016, 06:59 pm »
james
1ZIP
Re: BDP pi
« Reply #101 on: 15 Mar 2016, 01:24 am »
I like the idea of this thing.  Something simpler for those of us with less than 30,000 songs.  However, it does look like the other half is missing.   :D But, that's not going to prevent me from acquiring one.
Re: BDP pi
« Reply #102 on: 15 Mar 2016, 10:39 am »
Hi
I have about 41,000 songs on mine now and no issues.  The power supply is a wallwart so thats whats missing from the picture.
james
Krutsch
Re: BDP pi
« Reply #103 on: 15 Mar 2016, 12:18 pm »
Hi
james
How does it sound, compared with the BDP-1/2?
Re: BDP pi
« Reply #104 on: 15 Mar 2016, 01:17 pm »
It sounds different than the BDP-2.
It is a bit more forward sounding, a little more 'digital' in its tonal balance and the tonal balance seems a little tipped up. But I think its a great introduction to digital audio for those on a budget.
james
Re: BDP pi
« Reply #105 on: 16 Mar 2016, 03:40 pm »
Hi Folks,
Here is a picture of the Bryston Pi Digital Player internals with the modifications we have implemented:
Bryston Pi Mods
1. Power regulator circuit that accepts 7-14 volts, AC or DC from a 2.5mm barrel connector. This circuit also contains over voltage protection/indication and under voltage indication. Indication is provided by a rear mounted LED and the brightness can be adjusted by way of a pot mounted behind the LED.
2.  Bryston output stage for a clean strong signal and impedance matching.
3. The HiFiBerry Digi+ circuit, based around the Wolfson WM8804 digital interface transceiver.
4.  Peripheral connector for display, buttons and IR receiver.
Re: BDP pi
« Reply #106 on: 17 Mar 2016, 07:09 pm »
miatadan
Re: BDP pi
« Reply #107 on: 17 Mar 2016, 08:09 pm »
Would the performance be better with usb compared to optical or toslink digital?
 Compared to original BDP-1 , is the sound quality comparable?
Any optional power supplies to be available to replace wall wart basic power supply?
Re: BDP pi
« Reply #108 on: 17 Mar 2016, 09:03 pm »
Hi
The BDP-1 is going to sound better in my opinion.
The Pi can be used with the MPS-2 but not with USB drives that are not powered. OK with a NAS or Thumb drives or powered USB drives.
We are looking at making the new Phono Power supply be able to work with the Pi but will be a while.
james
unincognito
    • bryston.com
Re: BDP pi
« Reply #109 on: 17 Mar 2016, 09:07 pm »
https://dl.dropboxusercontent.com/u/86196657/Videos/BDP%CF%80/BDP%CF%80.m4v
higher-res and fixes an unexpected delay on slide 8
MadScientist
Re: BDP pi
« Reply #110 on: 21 Mar 2016, 07:47 am »
I think the cheaper endpoint option is a good move.   If it has support for Roon, I'd buy one (or two).
Jimmy71
Re: BDP pi
« Reply #111 on: 3 Apr 2016, 06:49 pm »
Hi
james
Hi James will a SSD external work fine with it and do you prefer USB over coaxial? I haven't heard coaxial yet that is why I am asking.
Re: BDP pi
« Reply #112 on: 3 Apr 2016, 07:02 pm »
Hi Jimmy
SSD's will probably not work unless it is powered
I find on the Pi they sound very similar.
james
schmidtmike76
Re: BDP pi
« Reply #113 on: 4 Apr 2016, 01:04 am »
james
Did you use the BDA-2 or 3 when trying the Pi out?  I just ordered the BDA-2 today and waiting for the Pi to come out if the sound quality is as good as the USB-1 I heard.
25x
Re: BDP pi
« Reply #114 on: 10 Apr 2016, 04:26 pm »
The BDP pi sounds really nice and interesting!
I have not had any of such audio player so far but I´m looking into buying one since some weeks. Most players are not what I´m looking for or way above my limit. The pi seems the perfect budget player with additional functions.
Some questions:
How is the pi controlled using a tablet, by app or browser?
It seems you also could use an IR remote. What means that IR socket at the rear of the pi?
What functions could be controlled by the IR remote?
Regarding use of USB devices, what would be the limit of current draw? I personally use Samsung SSD which have replaced most of my HDDs. Their 850 Evo seems drawing very little power, 30mW idle and around 2W reading/writing.
tulysses
Re: BDP pi
« Reply #115 on: 17 Apr 2016, 12:43 am »
Interesting new device, but not sure why the BDP-USB was discontinued. Can you elaborate?
Re: BDP pi
« Reply #116 on: 17 Apr 2016, 01:41 am »
HI
Used both with good results.
james
25x
Re: BDP pi
« Reply #117 on: 17 Apr 2016, 08:24 am »
No replies to my questions?
Re: BDP pi
« Reply #118 on: 17 Apr 2016, 10:08 am »
Some questions:
Sorry 25 just saw this - thanks for the poke.
You can use your computer or your phone or a laptop or a tablet to control.  I use an IPAD which is very popular but I recently bought one of those windows non-fan light weight units and it works great as well.  The Pi is a Linux operating system so there are many third party Apps you can use for control and the is a built in Bryston Web GUI which I use all the time now. The Bryston BR2 remote can be used but it has limited functions - I would recommend a tablet.
I am not sure on the total wattage or amperage but I will let Chris answer that one.  I have never had an issue with any of my SSD USB or Sata drives.
james
unincognito
    • bryston.com
Re: BDP pi
« Reply #119 on: 18 Apr 2016, 03:48 pm »
Some questions:
You should be able to power one USB drive off the unit, we've currently tested 1TB Seagate that draws about 500mA.  The BDP Pi has a IR receiver on the front of the unit which which can be used with the Bryston BR2 remote or an Apple Remote (limited testing on functionality).  The IR TX connector on the rear of the unit is for connecting an IR LED accessory (i believe this is being included with the product), this will allow you  to control other Bryston products from the BDP-Pi.  This functionality will initially be limited, but a feature that will be expanded as we develop the software.  The IR is directly connected to the Linux computer so we have more control over remote capability and can release support for additional remotes by way of software updates.
Chris
