Bryston 3B repair gone haywire
0 Members and 1 Guest are viewing this topic. Read 14893 times.
G Georgopoulos
Re: Bryston 3B repair gone haywire
« Reply #40 on: 8 Feb 2016, 10:38 pm »
scotty is probably right,there is also another 22R close to output in both halves of the amp output,trace the pcb with the schematic to find out which 22R is,but first i suggest do a measurement of the output dc voltage is it positive or negative with reference to ground... :green:
KV4LQ
« Reply #41 on: 8 Feb 2016, 11:10 pm »
OK.  Would it be safe to power up the amp with the final transistors removed?
G Georgopoulos
« Reply #42 on: 8 Feb 2016, 11:29 pm »
not in this design mate...lots of bias and feedback from o/p  :green:
but you could check the o/p transistors out of circuit
KV4LQ
« Reply #43 on: 8 Feb 2016, 11:39 pm »
And how do I check the transistors themselves?
G Georgopoulos
« Reply #44 on: 8 Feb 2016, 11:56 pm »
too much time to describe here,basicly look for a short between emitter and collector(with multimeter)
here is a link on how to test
https://www.youtube.com/results?search_query=checking+transistors
KV4LQ
« Reply #45 on: 9 Feb 2016, 04:06 am »
Sweet thanks :thumb:
DFXSLC nick
« Reply #46 on: 2 Oct 2020, 10:09 pm »
Using a current and voltage regulated supply is probably the best way to protect your circuit and yourself at the level of troubleshooting that this amplifier seems to need. The 3B wont hate a variac but you can cause damage to circuits with voltage regulation, filament circuits etc. by under-powering the supply.
