Reference 20 review
0 Members and 1 Guest are viewing this topic. Read 28679 times.
Eisener Bart
Re: Reference 20 review
« Reply #20 on: 13 May 2016, 06:02 pm »
What is US retail price for Ref 20?
Eisener Bart
« Reply #21 on: 13 May 2016, 06:02 pm »
gammajo
« Reply #22 on: 13 May 2016, 06:29 pm »
To ECM and TedTag - any updates as your Ref 20's have settled in?
In terms of list price, when I purchased list I think was $7,600 which is a great deal given what they beat out. Don't know price now
John Casler
« Reply #23 on: 13 May 2016, 06:31 pm »
Yes, Retail Price on the REFERENCE 20 Monobloc pair is $7600.
Eisener Bart
« Reply #24 on: 13 May 2016, 06:36 pm »
Thank you!
So price remained same as for Ref 18 (I remember review of Chris Martens somewhere).
In my case - I can buy it anywhere (despite we have Ukrainian dealer at Kiev), no voltage restrictions and weight is not so high, 2 packed block will be around 12-13 kgs. I have limits 40 kgs as seaman.  :)
Hmm, it looks like last purchase of power amps for me. :scratch:
John Casler
« Reply #25 on: 13 May 2016, 06:44 pm »
Thank you!
When the Ref 20 came out the Ref 18 price dropped to $6500
Eisener Bart
« Reply #26 on: 13 May 2016, 06:51 pm »
Not significant difference for me. I mean - between 7600 and 6500. I wanna Ref 20.
rustydoglim
« Reply #27 on: 13 May 2016, 08:35 pm »
The Ref 18 has been discontinued and Ref 20 will now shipped with the NuPrime logo on it instead of NuForce. There is no change in the design.
When NuPrime was first created, we took over the high-end line with 18 months of licensing rights to the NuForce logo so that there is a continuation without confusion.
Since then, NuPrime has grown far more than we have ever dream of, with four product of the year awards in 2015.  So it is the perfect time in 2016 to put everything under the NuPrime brand.
Eisener Bart
« Reply #28 on: 16 May 2016, 06:58 pm »
rustydoglim,
can you describe, what is the difference between 18 and 20?
thank you in advance!
rustydoglim
« Reply #29 on: 16 May 2016, 09:20 pm »
Ref 20 has a scaled up V3 board (for more power), bigger power supply. Increasing the power and yet improving the sound quality is no easy task.  Ref 20 has more dynamic and slightly deeper bass.  We are talking about small differences here. At this level you are not going to see big change.
Eisener Bart
« Reply #30 on: 17 May 2016, 11:54 am »
Thank you!
2 questions more:
1) I didn't find photo of remote control unit for P-20. There is only description in words only in review of Edgar Kramer.
 http://www.6moons.com/audioreviews/nuforce18/1.html
2) Which fuses are used in Ref-20 and P-20? I have some spare AMR Golden Fuses which I am using 3 years with great results. I want to check - may be I will buy additional fuses now.
dr.sah
« Reply #31 on: 17 May 2016, 11:59 am »
P-20 has same remote as P9 or IDA-16 (same design, different buttons function)
Eisener Bart
« Reply #32 on: 17 May 2016, 12:16 pm »
I found it, thank you!
Eisener Bart
« Reply #33 on: 20 May 2016, 08:39 pm »
rustydoglim
« Reply #34 on: 22 May 2016, 07:56 pm »
Slow blow, 5A, 250VAC
Eisener Bart
« Reply #35 on: 22 May 2016, 08:08 pm »
How many pieces totally in 3 units?
rustydoglim
« Reply #36 on: 23 May 2016, 03:33 am »
What do you mean?
Eisener Bart
« Reply #37 on: 23 May 2016, 09:50 am »
What do you mean?
How many fuses are used in:
1) power amp,
2) pre amp?
rustydoglim
« Reply #38 on: 24 May 2016, 05:00 pm »
One only, at the AC socket.
Eisener Bart
« Reply #39 on: 24 May 2016, 05:14 pm »
Thank you!
