FOUND: pre amp with specific features
0 Members and 1 Guest are viewing this topic. Read 1332 times.
audiojan
« on: 5 Feb 2016, 06:19 pm »
Found what I need. Thanks!
« Last Edit: 8 Feb 2016, 03:54 pm by audiojan »
LostInPA
Re: WTB: pre amp with specific features
« Reply #1 on: 5 Feb 2016, 06:57 pm »
I have one for sale, with the Level 2 modifications from Parts Connexion.  Asking $2,20.00 plus shipping, from ZIP 18661.  Details from dealer ad shown below:
Our mod was designed by Chris Johnson, the founder and former president of Sonic Frontiers.
The following details the Level-1 modification:
 a) We add 1 DEXA Technologies “discrete” DUAL op amp module to the input buffer.
b) We upgrade 4signal path resistors with KIWAME 2-watt 1% Carbon Film resistors
c) We upgrade the power supply regulators with 2 DEXA Technologies “discrete series” regulators (+ & - 15V)
d) We replace the inexpensive AC connector with a FURUTECH Rhodium-plated AC inlet
e) 10 feet of WBT Solder is used throughout the mod
 f) 4 hours labor are required to complete the mod
Sonic changes of our Level-1 mod:
Better low-level detail and 3D ambiance retrieval
Macro dynamics are improved It seems to play louder, with improved microdynamic contrasts
Midbass is improved to add weight to voices and make them sound more real
The midrange is a little more liquid than the stock machine's
Imaging is more defined, soundstage depth is enhanced
Bass extension and impact are improved with more weight and authority
The high frequencies are a little smoother
        Prices
                                         The Level-1 modification to your preamp is $750.00 + freight
                                          New modified preamps are available for $2,595.00 + freight
                                                 One year warranty on mod work to your preamp.
                                                New preamps have a 1 year Underwood warranty
We also have a Level-2 modification that is more comprehensive at $1,400.00 to your machine. New Level-2 modified preamps are $3,190.00+ freight.
 The Level-2 takes all of the level-1 and adds:
1) Two additional DEXA Technologies “discrete” DUAL op amp modules. One for each output buffer.
2) 6 Mundorf AG-Series main Power Supply filter caps at 22,000uf 25V each
audiojan
« Reply #2 on: 5 Feb 2016, 09:07 pm »
PM sent
cliffy
« Reply #3 on: 6 Feb 2016, 02:39 am »
I need a pre amp with at least one XLR in and XLR out, HT bypass that can be activated via trigger or RS232 and at least one RCA input.
The only one I've found that fits that bill is W4S STP-SE, but I'm sure there's other options. If you are selling a STP-SE or any other that fits the description above, let me know.
Check your PM.
gfederys
« Reply #4 on: 6 Feb 2016, 01:07 pm »
Yet another PM sent.
cliffy
« Reply #5 on: 6 Feb 2016, 03:31 pm »
I have a Sherbourn Pre-1 preamp that meets all your criteria.  It has RS232 control that can engage HT bypass.  I have the RS232 protocol .PD downloaded from the internet that I will provide as well.
I bought this preamp new but only used it for a couple months.  It is rather large physically and didn't meet the spouse's visual approval.  :?
Let me know if you are interested.
Spencer
