0 Members and 1 Guest are viewing this topic. Read 196668 times.
Sorry to follow up on my own post. Is there somebody out there who can PM me a version of the users manual in English? Thanks.
My plan was to purchase an Yggdrasil later this summer, running a disc spinner through it via coax or optical since I have 300+ redbook CD's and purchase an music server (possibly a HAL 3) later this year or early next year. Reviewers have said the Yggy does wonders with redbook CD's, any idea how the Gustard X20U would sound with redbook discs? Thanks- Martin
Marty,Did you compare the Yggy to the Gustard playing redbook discs?Thanks- Martin
Martin, Rich's HAL 3 server is a great buy, sounds superb and you can't get better customer service.
Uptone Amber Regen update: I'm still struggling with network issues, but I was able to get my USB output on my Aurender to work again, which means my Uptone Regen works again. Pretty big improvement over the AES input I'd been using for the last couple weeks.Now I just need to figure out WTF's going on with the Aurender on my network.
Have you updated your Aurender? I know the latest update made some very needed changes.
What are you using for NAS? I finally got my Synology DS716+ and have it up and running (about a month and a half) and it seems to have lots of updates too. I suspect the other post with the Aurender firmware is more likely the culprit. I dragged my HAL MS-3 to the dealer to compare it to an Aurender N100H but his Berkeley Reference DAC driver didn't like Windows 10 so hopefully sometime over the next month he'll lend it to me.
Phil,I'm still using the MS-3 as my NAS. I'm a bit suspicious that something done when fixing my MS-3 has something to do with the issue since these issues started after I got the MS-3 back. Hopefully getting everything hardwired and rebooted in place will put things right again. The MS-3 is still running WIN8.Evan
Evan - are you using something like? - http://lifehacker.com/5822590/turn-an-old-computer-into-a-networked-backup-streaming-or-torrenting-machine-with-freenas
Evan,Have you tried running the MS-3 without the extension router and just the WiFi to your network?
