0 Members and 1 Guest are viewing this topic. Read 196462 times.
Now a SERIOUS question: What dac did the Gustard X20 replace in your setup?Or what I really would like to know and hear is how does the X20 compare to some of the current HOT models in the same price range of about $700-$2000?I.E. Yaggi Benchmark, used like a older Lampi or new. A couple tubes or none at all.Quadman: I will try a few of the simple DIY you mentioned even though I don't own the unit and I was only tasked with BURNING it in and being the receiving agent of the shipment. Any thoughts of removing the volume circuit (if that wouldn't cause a major cost or issue)I tend to prefer using the Pre Amp so as not to degrade the digital signal since a majority of my listening is with the wife at home and that requires @-40 db to keep the hackles down.Also anybody used any of the inputs beside the USB, OPTIC or COAX? What has you experience been.In the next week I will try all of the inputs that I can with current equipment.
Let me know if you want a manual as they don't come with the units. Or at lest that is the common rule.Alan
I didn't view all of them, but those are beautiful photographs on your website. Michael
I don't have a definite answer to this question. IIRC you must have software (Audirvana, Jplayer, HQ Player, or ??) installed. Nc42acc, ACHiPo, or quadman are more knowledgeable, so I suggest asking one of them directly.I own a Mac Mini, but I don't have any of the above mentioned players. My buying the DAC came about faster than I had anticipated - a moment of weakness it was.
Or perhaps a moment of clarity and wisdom
I ordered X20u, was thinking how I could use the i2S input for DSD256/DSD512.
Ok, so minor surgery complete and the patient is stable. Stock fuse replaced, power supply wires twisted (you don't need to removed the sleeve), and transformers set free from their mounting bolt and isolated with rubber coasters. Will give it a listen tomorrow morning.
Kewl. I'm very interested to learn what this does. Did you brace the transformers, or are they 'loose'?
Are the improvements enough to make you recommend others try them, or is this something that one could choose to not do and just be happy with stock?~~~~~~~~~~~~~~~~I'm now 'speakerless'. In preparation for our return to the States, I dropped my LS/5-R speakers and their stands off at a good friend's home yesterday. They will enjoy the (huge) improvement in SQ over their Bose HT setup plus they will care for my speakers while I am gone. I didn't relish leaving my speakers exposed to the heat and humidity of summer. They run the AC all summer long. Oh, wait. I've got my wife's Jambox. Ooooh, sweet....
