0 Members and 1 Guest are viewing this topic. Read 6464 times.
I think high bit rates can sound real good. IMO however the quality of the recording is the most important criteria regardless of the format. But I prefer to listen to a version of a song that I like over a higher quality sound version.An example of this Rush's - Moving Pictures- Camera Eye- hi-rez. I prefer the cd version,and if you listen carefully is not the same recording. Most likely a studio practice version which was well recorded.
Some quick thoughts....1. Many have said high rate PCM sounds better than DSD.2. High rate PCM has less HF noise than DSD (as you can see easily on a scope).3. If you use digital volume control on your media player (JRiver, for example), DSD is converted to PCM, scaled, then converted back to DSD.4. DSD limits connectivity, media player options, DAC options, link reliability, and more.So, the question is "Why not just convert DSD to high rate PCM?". I know many on here have had much more experience with DSD playback than me. Looking forward to some feedback.Thanks for reading this.-Tommy O
Depends on the source. Was it old analog tape? What sample rates was it sample to? DSD? Double DSD? 24/96? 24/192? 24/384? etc. As the other post noted the quality of the recording/original source is really important. So I'm also suggesting it may be depending on what one is taking that source from. If it is 24/192 PCM and one is taking it to DSD lets say for the sake of making it more appealing to a certain audio segment then it probably is a bad thing. The problem is that we consumers all don't have a choice in most cases. It the best available source is an SACD, then I'd buy the SACD. If there is a hi-rez PCM source and the SACD, then I'd like most of us would choose the hi-rez PCM. Also in cases, the source is not transparent as to what it was. I don't get all wrapped up in what it is. If I like the music, I'll go for the best version available. I'll look to forums like this or sources like this for information - http://dr.loudness-war.info/album/list?artist=Steely+Dan&album=aja and make the best informed choice I can from whatever facts and/or opinions are available.
Absolutely. I don't listen to music because it sounds good on my hi-fi. I have a hi-fi so that I can enjoy the fullest of the music I want to listen to.
dude, I would say 75% of my listening is on sh*t gear relative to my hi-fi, but I don't get enough time listening on the hi-fi. For me, I almost completely shut out the audiophile aspect, except when I want to choose something for my system, which I haven't done much to in quite a while. I used to post here all the freakin time, now I mostly post about music or the odd thread here or there. (I was a moderator on a few sub-groups from way back). Times change, I realised that I just have to like how my stereo sounds so I can enjoy music without bitching too much. Most of my bitchin is because I spent too much for it not to sound right. In that end, I found setup and acoustics are 10x more useful than exotic cables, tube rolling, this or that upgrade in components.. I am not trying to preach or act holier than thou. I learned by the school of hard knocks.
