0 Members and 1 Guest are viewing this topic. Read 6104 times.
I would like suggestions, tips and what to avoid on a Split 18K BTUs cool only.Brands avaliable on market are:Consul, Gree, LG, Samsung, Komeco, Electrolux, Fujitsu, Carrier, Springer.Thanks
I researched this to death last year and wound up buying a 24K BTU (2 ton) Mitsubishi 19 SEER. So far, so good. What you choose should be governed by local circumstances, product reliability and availability and budget. I think it is wise to buy the highest SEER number you can get.
I'm not asking for instruction - my question is whether efficiency is linear with (delivered) output. If you have no idea, fine, no worries.
Typically John, all else being equal, efficiency should go up with machine size.
Well, from the line of units that I looked at, that was not the case (the opposite in fact). That is why I asked.To rephrase the question: suppose a 6kW unit has the same efficiency rating as a 3 kW unit. If I run the 6kW unit at half power, will it be as efficient as, less efficient than, or more efficient than the 3kW unit run at full power?
This is NOT a definitive answer. I remember my wife (Civil Engineer who has worked in Inspection/Plans/Code Enforcement for most of her career) telling me that getting too large of a unit for your space is not good. You lose efficiency. From her statements, I believe you are correct - they are not linear. You want them to run at/near their max capacity for greatest efficiency.
It just occurred to me why we are talking about air conditioning - some of you are in summer.
