FS: Manley Labs Stingray Stereo 12 Tube Integrated Amplifier - Excellent
0 Members and 1 Guest are viewing this topic. Read 2653 times.
HiGHFLYiN9
This is the 1.5 version version with the RECORD output, subwoofer output, TAPE LOOP, and the TRIODE/ULTRA-LINEAR switches. This was new dealer demo purchased from a dealer approximately 5 years ago. It has never been modified and I am the original owner. It includes the original box and manual. It was completely re-tubed two years ago with new JJ power tubes and NOS input/driver tubes. There are no notable scratches or dents on this unit, it has been sitting on the same shelf for it's whole life span ;) It works extremely well and sounds fantastic.
Here's a listing of the features:
Separate left and right silver-contact select switches (for the four stereo line inputs) deliver your music into the premium Noble balance and volume controls before hitting the first 12AT7 input tubes. The advantages of a passive preamp driving an extremely short and low capacitance two inches of cable are well known: near-absolute transparency, no added noise, and extreme signal path simplicity. This is the perfect place to implement a passive preamp as it were.
Following the mighty 6414 driver/phase splitter, the trusty EL84 output stage can be switched between either around 20 watts of TRIODE or 40 watts of Ultra Linear mode push-pull operation. Individual bias for each tube is easily adjusted using the trimpots and test points, conveniently located on the top surface of the amplifier. The Stingray's power supply is extra-rugged and stiff, a MANLEY hallmark. It swims with the sharks: fast, agile, fluid, and with consummate authority.
Select between 20 watts of seductive and ethereal TRIODE mode or 40 watts more powerful Ultra Linear output tube operation.
Subwoofer OUT a line level output that is AFTER the volume control so your powered subwoofer follows the same volume as your main speakers.
Specifications:
Manley Stingray
4 x Stereo Line RCA Inputs
TRIODE - UL Switching
RECORDING OUT
SUBWOOFER OUT
TAPE LOOP (Insert) with Bypass switch
Passive Noble Volume and Balance Controls
All-Vacuum Tube Lo-feedback Stereo Integrated Design
Output Tubes: 8 x EL84 Ships with Russian NOS EL84M (aka 6Pi14Pi-EB) (We are out of Ei 6BQ5)
Driver Tubes: 2 x 6414 Ships with GE or RAYTHEON JAN NOS USA or 6414W
Input Tubes: 2 x 12AT7EH Ships with: 12AT7EH large plate Electro-Harmonix Russian
Maximum Output Power UL mode: 40 Watts x 2 channels 1.5% THD @ 1kHz
Maximum Output Power TRIODE mode: 20 Watts x 2 channels
Frequency Response: 15 Hz - 40 kHz, -1dB
Gain: 37 dB at max Volume
Input Sensitivity: 185 mV in = 50 watts out into 5 Ohms
Input Sensitivity Triode: 66mV in = 1W into 8 Ohms
Input Sensitivity UL: 53mV in = 1W into 8 Ohms
S/N Ratio: typically 87 dB A-WGT, 20Hz-20KHz
Input Impedance: 50 kOhm nominal
Optimum Speaker Load: 5 Ohms
Actual Output Impedance at 20Hz: 2.8 Ohms at 100Hz: 2.6 Ohms at 1KHz: 2 Ohms
Damping Factor: 5
Scratch Factor: Use pennies under pointed feet to avoid marring cabinetry. Try quarters if you are in upper tax brackets. The bargain performer would be nickels. Paper currency does not function as well. Euro coins work 1.54 times better.
Power Consumption Idle: 200W
Maximum Power Consumption at Full Power: 370W
MAINS Fuses: 100~120VAC operation: MDL 3 AMP / 250 Volt SLO-BLO 220~240VAC operation: MDL 1.5 AMP / 250 Volt SLO-BLO
B+ FUSES (2): MDA 1/4 AMP, 250 Volt SLO-BLO, Ceramic. (Located internally)
Power Supply: is factory set for 100V, 120V or 220-240VAC operation for original destination country's mains voltage.
Operating Mains Voltage: changeable with power transformer re-wiring on PCB and fuse value change.
**SHIPPING - This item has been carefully packaged
Shipping weight:  30 lbs
Shipping dimensions:  18x18x10
Will likely use insured FedEx for this shipment.
blownrx7
Unless I missed it scrolling back and forth...
What's the price?
Where are you located?
TIA
glynnw
  • I have tin ears.
I'll bid $25.00    :lol:
audiojem
PM Sent
HiGHFLYiN9
Woops! That's a pretty important part of the post, right?? :duh: It's $1485 Shipped in the U.S. Audiogem was the first to send me a message so he's first in line. If I don't hear back by tomorrow then it's available.
dapoun
sent you a PM
