Stuck between two primes: Canon 35mm f/1.4L or 35mm f/2 IS
JimJ
  • Ut Prosim
Little background - I have a 60D crop body, mostly do street/cityscapes/nature/travel stuff. I bought a non-IS 35mm f/2 a year ago, and it's been a dog. Looking to upgrade, and I've decided between the 2012 revision, the 35mm IS, and the first generation 35mm L lens.
The L has much better build quality, of course, but has anyone compared these two lenses directly? I see that the f/2 is obviously pretty bad wide open as far as vignetting goes, but I'll probably be stopping down to at least f/4 most of the time anyway.
thunderbrick
  • I'm just not right!
Re: Stuck between two primes: Canon 35mm f/1.4L or 35mm f/2 IS
« Reply #1 on: 6 Jan 2016, 08:24 pm »
Skip the 1.4 and save money.
And what's the "dog" problem with the old lens?
JimJ
  • Ut Prosim
« Reply #2 on: 6 Jan 2016, 08:58 pm »
It's reasonably sharp in the center, but the corners don't look very good at all.
thunderbrick
« Reply #3 on: 6 Jan 2016, 09:39 pm »
Well, that's a pretty good definition of a "dog" lens.   :wink:
Folsom
JimJ
  • Ut Prosim
« Reply #5 on: 9 Jan 2016, 12:59 am »
Going with the non-L 35mm IS. I just can't justify the extra for how little I'd be shooting either of them wide open.
May be shopping pretty heavily locally tomorrow - nearby camera shop is a B+W and Blackrapid dealer, too...could be trouble...
Folsom
« Reply #6 on: 9 Jan 2016, 01:28 am »
The L will be worth something in the future. The IS shoots as low or lower light, But isn't going to retain value. I'd go with L for quality of image and value retention.
