BDA-2 output impedance
0 Members and 1 Guest are viewing this topic. Read 1805 times.
R. Daneel
« on: 6 Jan 2016, 01:54 pm »
Hello!
What is the output impedance of the BDA-2 through it's XLR and RCA analog outputs?
Is BDA-2 suitable for use with a passive preamp to drive a power amp with an input impedance of 10 kOhm?
Antun
R. Daneel
Re: BDA-2 output impedance
« Reply #1 on: 8 Jan 2016, 05:39 pm »
Someone? Anyone?
srb
« Reply #2 on: 8 Jan 2016, 06:28 pm »
In the Audioshark audio forum, James Tanner stated that the output impedance of the BDA-2 DAC was
RCA – 72 Ohms
XLR – 72 Ohms per leg
http://www.audioshark.org/bryston-audio-40/bda-2-output-impedance-8377.html
I'm sure, impedance wise, it would drive the power amplifier just fine, but as you know even with a good impedance ratio some users say the sound is not quite as full (lean?) with a passive preamp vs an active preamp stage with gain.
R. Daneel
« Reply #3 on: 8 Jan 2016, 07:16 pm »
RCA – 72 Ohms
Thank you Steve!
I was just trying to see whether this wpuld work or would using the BHA-1 headphone amplifier as a preamplifier yield better results.
Cheers!
Antun
srb
« Reply #4 on: 8 Jan 2016, 07:33 pm »
I was just trying to see whether this would work or would using the BHA-1 headphone amplifier as a preamplifier yield better results.
Yes, if you try the comparison, report back with your subjective sound quality evaluation.
I only tried a DAC direct to power amp once, but because it was an early version Emotiva XDA-1 DAC with incorrectly programmed linear vs logarithmic volume control, I only had 3 or 4 volume steps between lowest and highest volumes and couldn't really give it a proper evaluation.
werd
« Reply #5 on: 8 Jan 2016, 10:03 pm »
Yes there is ample gain too in the BDA2 to drive the passive pre amp, cables, etc. I did that for a long time into my 14B. Mind you that had 50k on the 14B impedance but still 10k is not low enough to drag the output down.
