Bryston announcing new SST3 amps
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston announcing new SST3 amps
« Reply #600 on: 1 May 2016, 04:00 pm »
Hi James,
So upgrading the SST2 units to Cubed series by the local distributor outside your factory is out of question, right?
Could one order the latest ^3 amps with the SST2 faceplates? I still like the idea of not having to explain much to my better half, when the budget allows for upgrades, hee hee. : )
Klao
Hi Klao
Yes it is definitely a factory upgrade if we get the OK.
I think the old faceplates will fit but you might want to include new faceplates as well as resale value would be poor otherwise.
james
GreenMtnGringo
« Reply #601 on: 1 May 2016, 09:39 pm »
Hi James, I am really enjoying my new 4B3 amp.  One quick operational question: Is it safe to toggle the rear Gain Select Switch between 23dB and 29dB while the amp is powered on, or should I turn off the power using the front Power/Standby switch before each throw of the Gain Select Switch?
Reason for asking: I have two primary source components, and one is quite a bit louder than the other at the same pre-amp volume setting.  I cannot turn the pre-amp volume pot past around 9:00 O'Clock when using the louder source component.  I find that my pre-amp sounds best with the volume around 12 O'Clock, so I was thinking of toggling the Bryston's Gain Select Switch down to 23dB when listening to this component, and then back up to 29dB when listening to the other one.
« Reply #602 on: 1 May 2016, 10:49 pm »
Yes that should be fine assuming you do not hear any pops during switching and I would leave the volume fully down when switching.
James
GreenMtnGringo
« Reply #603 on: 2 May 2016, 01:55 am »
Thanks, James!  I tried the Gain Select Switch with the amp power on and my pre-amp volume all the way down.  No pop at all, and it turns out that both source components sound fine at the 23dB setting, so I will likely leave the switch in that position.
« Last Edit: 2 May 2016, 02:29 pm by GreenMtnGringo »
Marius
« Reply #604 on: 2 May 2016, 01:50 pm »
HI James,
Would you still have 2 black 28b SST 17 inch faceplates, no handles, laying around? Im considering a swap, but if you don't have them anymore, ill stop ;)
Marius
« Reply #605 on: 2 May 2016, 03:22 pm »
HI James,
Marius
I will check.
james
« Reply #606 on: 3 May 2016, 10:03 am »
Hi Folks,
Sneak Peek:
SUBJECT: Bryston 4B Cubed Review in hi-finews U.K.
Favourite Quote:
“Ultimately I couldn't find anything that would trip up the Bryston 4B3, no matter what I fed it, the amplifier responded with effortlessness and poise.
It has a refinement and innate musicality that suggests it can turn its hands to anything, albeit in a manner backed by an underlying sense of mischief, and a feeling of power that is little short of addictive.
The measurements (from Paul Miller) are equally impressive overall.”
Adam Smith
« Last Edit: 3 May 2016, 11:37 am by James Tanner »
GreenMtnGringo
« Reply #607 on: 3 May 2016, 04:58 pm »
Hi Folks,
Sneak Peek:
Favourite Quote:
Adam Smith
Thanks for the review preview, James.  I have had my 4B3 for just over a week now, and I agree with the reviewer that the sound is addictive!  I find that I can hear much deeper into recordings that I thought I knew well.  The instruments and voices were all there before, but now with the 4B3 they are sorted out in such a convincing way, from front to back, side to side, and relative to each other, that it is uncanny.  I never owned a Squared amp, so I cannot offer a comparison on that front, but I can say that I have never heard my listening room or my Magnepan MG .7's sound so good!  Congratulations to Bryston on a great amp, and on the upcoming Hi-Fi News review!
« Reply #608 on: 3 May 2016, 05:00 pm »
Thank you for the feedback - much appreciated - ENJOY! :thumb:
james
wilsonij
  • BDP1>SP3>7B3s> Vandersteen Quatros
« Reply #609 on: 3 May 2016, 08:27 pm »
Looks like this will be out in about a week's time:
Do you know of any reviews of the 7B3 in the pipeline James ?
Everyone who's been round to my place to listen to mine have been blown away ! :-)
Ian
GreenMtnGringo
« Reply #610 on: 3 May 2016, 08:36 pm »
^^ STOP THE PRESSES!! ^^
"US muscle amp flexes its specs."  :duh:
« Last Edit: 3 May 2016, 10:38 pm by GreenMtnGringo »
dallyd31
« Reply #611 on: 3 May 2016, 10:54 pm »
I noticed that too. Yikes
« Reply #612 on: 4 May 2016, 12:17 am »
Ya we are still considered the "colonies" over here in N.America   :lol:
« Reply #613 on: 5 May 2016, 04:31 pm »
Marius -
Hi James;
The computer says we have 6 pcs of the 28BSST2 black 17” panel in stock.  $300.00 each, plus shipping, for dress panel kits.
Mike
Marius
« Reply #614 on: 5 May 2016, 06:37 pm »
HI James,
Thanks, unfortunately thats a bit steeper than i would have hoped for really. Gee, too bad.  :cry:
Maybe i should wait until you can't use them anymore in the current amp lineup ;) Thanks for checking though, much appreciated.
Marius
Marius -
Hi James;
Mike
Armaegis
« Reply #615 on: 6 May 2016, 03:01 am »
I think I asked this a couple weeks ago in a different thread, but will any of the cubed tech be eventually making it into the preamps or headamp?
« Reply #616 on: 6 May 2016, 09:47 am »
HI
I do not think so as the input circuits on the amplifiers do not really apply to the low level gain stages on the preamps and headamps.
james
« Reply #617 on: 7 May 2016, 12:46 pm »
SUBJECT: New Cubed Amplifiers – Thoughts!
Hi James,
Having a right run on the new Cubed 7B’s, sold 4 this week :-)
For me the noise floor just seems lower so you get a more dynamic sound if that makes sense, everything seems to erupt from an inkier black background but still very neutral and honest with just enough warmth to give a very lifelike presentation.
For me you guys still make the best amps in the world :-)
Paul Clark
Here to listen...
hifi lounge
4 The Granary Buildings, Millow Hall Farm, Millow, Dunton,
Bedfordshire, SG18 8RH, Phone:    +44 (0) 1767 448121
Email: [email protected]
Pundamilia
« Reply #618 on: 7 May 2016, 04:09 pm »
When will we begin to see all the rave reviews on the Cubed series from the audiophile trade press? :o
« Reply #619 on: 7 May 2016, 04:26 pm »
HI
It will be a while - we are very backordered and customers come first.
james
