Bryston announcing new SST3 amps
wilsonij
  • BDP1>SP3>7B3s> Vandersteen Quatros
Re: Bryston announcing new SST3 amps
« Reply #580 on: 22 Apr 2016, 03:52 pm »
Is that correct? It seems counterintuitive.
I thought that too until I read the manual !  :duh:
I'd assumed that it was an "ON/OFF" switch but it's not ! It's actually a trip switch (very much like what you have in a house fuse box) which then made sense of why it needs to be flipped to the "on" position before power is reconnected.
Simples !  :D
Ian
G E
« Reply #581 on: 24 Apr 2016, 01:01 am »
Hi, I am looking forward to receiving my 4B3 in the near future.  Can anyone recommend a good solid amp stand in case I want to get the amp up off the wood floor
Check out
http://www.timbernation.com/isolationplatforms_popup.cfm
I used one of the platforms under my 4bsst2. It is now under my turntable. I will get two more for my 28s
Also check out SolidSteel products. I have one of their midrange equipment racks
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #582 on: 24 Apr 2016, 12:53 pm »
http://av2day.com/2016/04/bryston-4b-cubed-power-amp-and-bda-3-dac-launched/
james
James the Cube is fantastic, it's a big jump in subjective sound over the square and it goes a lot louder before clipping...
memota
« Reply #583 on: 25 Apr 2016, 11:36 am »
James,
Any idea when the 135 squared is coming out? I notice the web page says new photos coming soon.
I'm secretly hoping I'll be able to update to cubed status.... Either way interested.
Cheers!
GreenMtnGringo
« Reply #584 on: 25 Apr 2016, 12:08 pm »
Check out
Great suggestions, thanks!
« Reply #585 on: 25 Apr 2016, 12:23 pm »
James,
Cheers!
Hi
All current B135's are already Cubed versions.  The cosmetics have not changed.
james
memota
« Reply #586 on: 25 Apr 2016, 12:52 pm »
Hi
james
Thanks James.
I presume the silk screening will change? Hence the comment on the webpage that the photos currently show the old version?
Any news on ability to upgrade my 135?
« Reply #587 on: 25 Apr 2016, 01:42 pm »
Thanks James.
Hi
I am not sure that can be done - I will check with Mike.
james
adol290
« Reply #588 on: 25 Apr 2016, 07:12 pm »
James,
What is the current wait time on the 7b's, once you have the order.
« Reply #589 on: 25 Apr 2016, 07:39 pm »
James,
Hi
Depending on colour and size about 2 weeks.
james
95Dyna
« Reply #590 on: 27 Apr 2016, 01:36 am »
Haven't been on the A/C site for a while.  Is there an update on the availability and cost to upgrade from 7BSST2 to 7B3?
« Reply #591 on: 27 Apr 2016, 01:48 am »
HI
No sorry not yet - still trying to get the certification bureaucracy to allow us to do upgrades without having to have them certified.
james
« Last Edit: 27 Apr 2016, 09:57 am by James Tanner »
Armaegis
« Reply #592 on: 27 Apr 2016, 07:46 am »
Any chance the Pro Cubed amps can come with speakon connectors?
« Reply #593 on: 27 Apr 2016, 09:58 am »
Hi
No sorry they will have standard 5-way.
james
planet
« Reply #594 on: 28 Apr 2016, 09:53 am »
Hi. What is the most suitable power cable for the cube amp?
CanadianMaestro
« Reply #595 on: 28 Apr 2016, 11:20 am »
Now that's a real can of ghoulash.    :o
Armaegis
« Reply #596 on: 28 Apr 2016, 03:09 pm »
Short and thick. Seriously.
« Reply #597 on: 28 Apr 2016, 03:33 pm »
Hi Folks
From Inner Ear Magazine:
klao
« Reply #598 on: 1 May 2016, 12:51 pm »
Hi James,
So upgrading the SST2 units to Cubed series by the local distributor outside your factory is out of question, right?
Could one order the latest ^3 amps with the SST2 faceplates? I still like the idea of not having to explain much to my better half, when the budget allows for upgrades, hee hee. : )
Klao
Rod_S
« Reply #599 on: 1 May 2016, 02:14 pm »
Very sneaky :D
