Bryston announcing new SST3 amps
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston announcing new SST3 amps
« Reply #1080 on: 28 Aug 2021, 10:57 pm »
Well it looks like I will be ordering  a new set of Bryston 28B Cubed..........;-)
Hi There
They will be fabulous with your Model T's
james
1oldguy
« Reply #1081 on: 29 Aug 2021, 11:21 am »
Does anyone have a good picture of the amps in black/....Really hard to see what the new black looks like.
1oldguy
« Reply #1082 on: 29 Aug 2021, 04:17 pm »
Hi James
Perhaps you could tell me if the new black on the cubed series looks different than the squared black ?
If so ,how would you describe it?
« Reply #1083 on: 29 Aug 2021, 04:36 pm »
Hi James
Hi oldguy,
The Black is the same as it has always been over the different series.
james
1oldguy
« Reply #1084 on: 2 Sep 2021, 12:28 pm »
James....It's  official......The order for the 28's are in....!!! Going with Black with handles.
 :popcorn:
« Reply #1085 on: 2 Sep 2021, 12:59 pm »
 :popcorn:
Excellent -  :thumb:
Who did you order through and I will keep a lookout for you.
james
1oldguy
« Reply #1086 on: 2 Sep 2021, 01:34 pm »
It was with Mark Jones Audio.
1oldguy
« Reply #1087 on: 2 Sep 2021, 08:26 pm »
HI James......do you sell dust covers for your amps?
« Reply #1088 on: 2 Sep 2021, 08:53 pm »
Sorry I did not know we ever did - enlighten me please. :)
james
1oldguy
« Reply #1089 on: 3 Sep 2021, 12:44 pm »
Ok.....Guess that's a no.......i can't be the only one who would buy a dust cover?  If you sold them that is. :o
john1970
« Reply #1090 on: 3 Sep 2021, 12:49 pm »
Amp covers would be an interesting idea although I am not sure what the market would be.  If you are worried about dust getting into the vents when not in use a simple lint-free towel could work.
Best,
John
jbuzas
« Reply #1091 on: 3 Sep 2021, 05:25 pm »
Look on Ebay. You can find nice covers for Bryston amps (and other manufacturers).
drummermitchell
« Reply #1092 on: 4 Sep 2021, 12:31 am »
Take a look or see how much heat the amps put out,IMAGINE with a cover :duh:.
Towel :duh: :duh:.
Dust them off with a swiffer.
Even an an enclosed cabinet can make them over heat(depending on size).
Mine are open on all sides no troubles since 2006.
Personally some of the Q+As are WTF.
1oldguy
« Reply #1093 on: 4 Sep 2021, 02:27 pm »
Towel :duh: :duh:.
I guess I should have said.......for when they are not on? Only when I am away!!!! i would imagine there are some who would actually use them with a cover while in operation!!! :lol:
NekoAudio
    • Neko Audio LLC
« Reply #1094 on: 4 Sep 2021, 05:21 pm »
If you want to order some custom-size dust covers, DigitalDeckCovers is a good resource. Very reasonable pricing and good service.
« Reply #1095 on: 8 Sep 2021, 08:03 pm »
Here is a picture of the Bryston 28B top being cut in the Doosan at our factory.
Markd51
« Reply #1096 on: 9 Sep 2021, 03:47 pm »
I'll second Digital Deck Covers as a good source for covers. I bought many from them to protect my entire system.
Their prices are reasonable, and the cover(s) will be to the exact sizes and specs you specify.
They can be gotten without their company logos on them, be sure to specify that should you order from them, and don't want logos.
You do the measuring, and one can account for bottom feet that the cover can be made a bit taller to fully cover the Amps.
I had many of my covers from them designed with an open flap on back.  This permits the covers to be easily put on, and removed with less effort, and the flap allows clearance for cables, but still  coverage and dust protection of all cables exiting the back of a component.
gbaby
« Reply #1097 on: 10 Sep 2021, 02:36 pm »
Under no circumstance would I put a cover over any amp.
brucek
« Reply #1098 on: 10 Sep 2021, 08:17 pm »
Yeah, seems like the worst idea in the world. It only takes one of the kids to inadvertently turn on an amp and your house could burn down.
What possible benefit could come from a dust cover. I've removed the lids on Bryson amps after 20 years and they're pristine as if manufactured yesterday.
brucek
NekoAudio
    • Neko Audio LLC
« Reply #1099 on: 10 Sep 2021, 11:32 pm »
Well, Bryston amps have a thermal shutdown protection feature. But dust covers can help if you are worried about something falling into the amplifier when unattended or not in use, be it small physical objects or liquid. It's a calculation each person will need to make for themselves.
