Bryston announcing new SST3 amps
0 Members and 2 Guests are viewing this topic. Read 504285 times.
TJ-Sully
Re: Bryston announcing new SST3 amps
« Reply #1040 on: 11 Mar 2019, 11:42 am »
Go Canucks!
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1041 on: 25 Apr 2019, 06:23 pm »
Hi Folks,
Have a PDF manual of the new Bryston 9B CUBED 5 channel 200 watt amplifier available.
[email protected]
« Reply #1042 on: 10 Jun 2019, 11:04 pm »
Just wanted to praise you guys at Bryston for the amazing cubed series amplifiers!
I have been running for several weeks a pair of 7B3 Cubed mono blocks on my Sonus Faber Olympica 3 speakers. Your amps have replaced my 10 year old MBL 8011am mono amps. These amps listed for 15,000 dollars back then! I have to say the 7B Cubes are a mass improvement. I have lost the bass bloat from the MBLs and gained definition in all frequencies! What makes the 7Bs so special, is the fact they don't call attention to themselves! They just do their job! They will let you know what is connected up stream!
In my case it was a bonus since I am using a EMM labs pre 2 preamp. For digital the New Marantz SA10 flagship player with a VPI turntable. The 7B's have virtually disappeared from the system! I am telling all of my audiophile friends about your products!
Thank you to my Canadian neighbors for making such an incredible product at a very fair price!
Herb from New York!
« Reply #1043 on: 2 Jul 2019, 04:16 pm »
THE VERDICT:
Bryston has built a winner with the 28B cubed amplifiers.
Nothing can touch these in terms of performance for the price.
Just be cautious with the volume control. These produce so much clean power, a dB meter might be a good thing until you get used to just how loud they can play.
« Reply #1044 on: 28 Jul 2019, 01:57 pm »
SUBJECT: Bryston 14B Cubed & Magnepan MG-30
July 2019
James,
We used Bryston.
Dear Inmates,
Once again, extensive use of diffusers (at Codell Audio in Montreal) helps to make some of the best sound I have heard on these tours.
Reference Recordings made at Minnesota Orchestra sound like Jim Winey's 11th row seat (slightly to the right of center)
Wendell Diller,
Magnepan
Testsystems
« Reply #1045 on: 29 Jul 2019, 11:30 pm »
Hi James
You make reference to a new 9B3 above.  Is there a new 6B3 coming as well?  I don't see any details on the Bryston website.  Release date(s)?
Still loving my Bryston Active systems.
Tx
Drew
« Reply #1046 on: 30 Jul 2019, 11:34 am »
Hi James
Tx
Drew
Hi Drew
No I think we are going to discontinue the 6B as the new 620B Cubed amplifier is 6 channels at 200 watts and any 2 can be bridged to 350.
Glad you are still enjoying your Bryston Active systems - there is no going back once you have heard a good active system! :thumb:
james
servingko
« Reply #1047 on: 30 Jul 2019, 03:32 pm »
620B???   More details please!  With that being built at behest of Storm Audio and looking at the back panel, does this amp have the same circuit topology as the 9b or is it class D?
« Reply #1048 on: 31 Jul 2019, 10:35 am »
Hi servingko
Storm approached us about a 6 channel amp (they have Digital amplifiers already) for them and we decided to have our own version as well.
It is a Cubed amplifier but has Ethernet control etc. demanded by the custom installers. In our case there will be a version without fans and a version with fans.
It is at least 6 months out.
james
servingko
« Reply #1049 on: 31 Jul 2019, 04:56 pm »
Thanks for the update and a fanless version is a must!
Grit
  • - Garrett
« Reply #1050 on: 2 Aug 2019, 05:53 pm »
Any update on the 9B3?
« Reply #1051 on: 2 Aug 2019, 10:53 pm »
Hi
Yes we have shipped a few but are heavily backordered
James
Grit
  • - Garrett
« Reply #1052 on: 4 Aug 2019, 05:18 am »
Woohoo! When will the media hit the website?
I'm excited... means it might be time to upgrade to 9B3 and 4B3 :) :) :)
CanadianMaestro
« Reply #1053 on: 4 Aug 2019, 12:07 pm »
Stumbled on this review of 28B3. A hard lesson learned, apparently.
https://www.audio-activity.com/bryston-28bsup3-en.html
« Reply #1054 on: 4 Aug 2019, 01:56 pm »
Thanks I had not seen this - re-enforces the fact that there is no better/best in our amplifier selection - just match the power requirement to your speaker needs and there is no performance penalty with lower powered and less expensive versions of Bryston amplifiers.
james
« Reply #1055 on: 28 Oct 2019, 12:07 pm »
Hi James
New excellent Review on 3B CUBED in Germany under link:
https://www.fairaudio.de/test/bryston-3b3-endstufe-verstaerker-test/
Grit
  • - Garrett
« Reply #1056 on: 29 Oct 2019, 06:49 am »
Quick 9B3 question for James - I google-found a 9B3 manual, but the 9B3 doesn't show up on Bryston's website? Anyway, the manual shows 200W / ch @ 8 ohms. There's no power rating at 4 ohms though. What would it be? 300W?
« Reply #1057 on: 29 Oct 2019, 11:48 am »
Hi Grit
Yes 300 + watts.
james
« Reply #1058 on: 27 Dec 2019, 06:01 pm »
« Reply #1059 on: 11 Mar 2020, 11:45 am »
Hi Folks,
Great review from Tone Magazine on our Bryston 28B power amplifier - the best 'tweeter' amp in the world !!!
https://www.tonepublications.com/review/brystons-28b-cubed-power-amplifiers/
james
