Audio/Video Gear and Systems
Owner's Circles
The nOrh Owner's Circle
jqp
speaker grill pegs needed for 4.0s
0 Members and 1 Guest are viewing this topic. Read 5340 times.
SteveSatch
22 Dec 2015, 11:05 pm »
I need some grill pegs. 4.0s used short, fat ones and longer, skinny ones. I need some of the longer, skinny ones. Any idea where to get some?
jqp
Facilitator
Each CD lovingly placed in the nOrh CD-1
Re: speaker grill pegs needed for 4.0s
23 Dec 2015, 02:59 am »
The nOrh guys may be able to help you source them or may have them. Try an email from the current web site.
SteveSatch
Reply #2 on:
23 Dec 2015, 04:30 pm »
$5 for a pair and $25 shipping from nOrh. I will try to find elsewhere.
borism
Reply #3 on:
23 Dec 2015, 04:40 pm »
Parts Express has them ($ 2.50 for 8 pairs) and shipping is much cheaper (~ $6).
Peter J
Hmmmm
Reply #4 on:
23 Dec 2015, 04:42 pm »
Have you tried suppliers like Madisound or Parts Express? I've never had to match existing but they have several to choose from.
SteveSatch
Reply #5 on:
23 Dec 2015, 05:05 pm »
I was looking at Part Express and the ones they have look shorter/fatter than what I need. Since the peg has to match the hole in the metal grill ring perfectly I need the exact right size. Parts Express are this style:
http://www.parts-express.com/parts-express-pressfit-speaker-grill-guides-8-pair--260-366
I may try this one from ebay/China and hope it fits:
http://www.ebay.com/itm/Black-Plastic-Ball-Socket-Type-Speaker-Grill-Pegs-Studs-Buckles-100pcs-/321832274439?hash=item4aeeb2ca07
No biggie. I'll get it sorted. I just thought someone may know which ones.
jbgcpa
Reply #6 on:
6 Jul 2017, 06:36 pm »
I also need grill pegs for my 9.0 marbles. Does anybody know if the PartsExpress link below for the 4.0 will work for the 9.0?
I also got no response to repeated requests from nOrh. If anybody has contact info that works - I'd try them directly again. Thanks..
Owner's Circles
jqp
