OB H-Frame / A370PEQ / HX800 amp Box Flat Packs / Finished Cabs
0 Members and 2 Guests are viewing this topic. Read 290710 times.
mlundy57
Re: OB H-Frame / A370PEQ / HX800 amp Box Flat Packs
« Reply #420 on: 21 Dec 2018, 07:15 pm »
  I was going to use AE Dipole woofers for this build but, I've changed my mind. Servo Sub kit is the surefire way to go IMO. I need help deciding which kit. I'm thinking kit #4. I'll need a pair of boxes Jay.
For a two driver cabinet that would be the one. Remember, you will need one kit for each H frame.
mkane
« Reply #421 on: 21 Dec 2018, 07:17 pm »
 Thanks and I'll order this set-up with some No REZ
« Reply #422 on: 21 Dec 2018, 07:20 pm »
Kit 4  would be my choice  as well.  You could go with  kit 3  but I like the  flexability of the  A370PEQ.
Once  you  decide for sure, letme know  and we can  package  you up a  pair of amp boxes  for  either the  A370's or the  HX300's
I'd recommend you grab  4  sheets of no rez... you  won't use the full 4th sheet but  you'll be  shy  with only  3
jay
mkane
« Reply #423 on: 21 Dec 2018, 07:23 pm »
 Kit #4 bought and paid for.
mkane
« Reply #424 on: 21 Dec 2018, 07:25 pm »
 Darn, I ordered 3 sheets. Maby the seller will see this and add another sheet.
mkane
« Reply #425 on: 21 Dec 2018, 07:39 pm »
 I sent DR a pm. Hope he's the go-to man for this. Anyway, all is good. I'm now thinking epoxy base under paint is a nice way to finish these.
mkane
« Reply #426 on: 25 Dec 2018, 04:09 am »
And that's taken care of, thanks. 127/slo cure ordered with some micro balloons.
Bassaholic
« Reply #427 on: 26 Dec 2018, 09:44 pm »
Just received my OB-3s with amp boxes from Jay. Just a shout out for his help and craftsmanship.  Packaging was top notch as well. If you had any doubts about ordering these, fear not! Waiting on a pair of NXOticas now. Happy Holidays peeps
mkane
« Reply #428 on: 27 Dec 2018, 01:41 am »
 :thumb:
Bassaholic
« Reply #429 on: 27 Dec 2018, 01:46 am »
Jay and Danny are so helpful- even for noob DIYers like me- it’s been a pleasure working with these guys over the past several months
C
mkane
« Reply #430 on: 28 Dec 2018, 09:17 pm »
Nice and square. Foolproof. Used Titebond III.
« Reply #431 on: 29 Dec 2018, 02:52 am »
Glad to see them  coming  together  man   :thumb:
Might  be  a touch of  sanding   etc   where the     braces  meet the  side panels but  should be   minimal.
Keep us posted on  your  progress    ,  love  seeing  all the  different  finished  results
And  if you  need any  guidance   with regards to wiring. I set this thread up  a while back.     Did up drawings  for  most  confiigs... find  what matches  your cabs  and there will be  a  diagram and  a written   "follow along" to get  it right.
https://www.audiocircle.com/index.php?topic=149708.msg1600884#msg1600884
jay
mkane
« Reply #432 on: 29 Dec 2018, 03:23 am »
 :thumb: Grill frames hide all sorts of sins. These will be epoxied & finished with automotive type paint. Weather here is probably not conducive to attempt a finished job on these unless I do this indoors. Thanks for the link.
mkane
« Reply #433 on: 29 Dec 2018, 03:34 am »
 Just a thought. What type of fasteners are favored for attaching the speakers?
mlundy57
« Reply #434 on: 29 Dec 2018, 03:54 am »
They come with mounting screws
« Reply #435 on: 29 Dec 2018, 05:20 am »
Yeah they do.....
If the screws   are not  found in the  box,   check around  the  magnet  of the  woofer....   I've  found them in a  few  strange  places   LOL   this  was mostly on   earlier    drivers  I   got  from danny,  the   latter  ones  have  all been    sitting  inthe  little bag   just  as they  should  be .
jay
mkane
« Reply #436 on: 29 Dec 2018, 04:50 pm »
  Guess I need to open the box the speakers came in.
mkane
« Reply #437 on: 31 Dec 2018, 10:57 pm »
  Glued up the 2nd H Frame this morning.
mkane
« Reply #438 on: 31 Dec 2018, 11:00 pm »
  Can I listen to these using a Stereo power amp while I wait for the servo amp to get here? thx
Danny Richie
« Reply #439 on: 1 Jan 2019, 12:37 am »
You can. They will play and you can burn them in a bit that way. They just won't have the control.
