OB H-Frame / A370PEQ / HX800 amp Box Flat Packs / Finished Cabs
0 Members and 2 Guests are viewing this topic. Read 292826 times.
gregfisk
Re: OB H-Frame / A370PEQ / HX800 amp Box Flat Packs
« Reply #300 on: 27 Dec 2017, 08:48 pm »
Welcome Fernando,
Just respond back here a couple of times and you'll be in good shape. You know, tell us how great we are are something like that :lol:
Fernando M
« Reply #301 on: 27 Dec 2017, 11:33 pm »
Thanks for the reply.
Fernando M
« Reply #302 on: 27 Dec 2017, 11:34 pm »
I have been reading through Audio Circle and find it very imfromative.
« Reply #303 on: 29 Dec 2017, 05:36 pm »
Jay,
I am interested in a pair of open baffle subs. I have a few questions about the flat pack, could you send me a private email?
Fernando
All good, you should have received my PM.  LMK if yo uhave any other  ?'s  Fernando
jay
mdl62
« Reply #304 on: 30 Dec 2017, 11:53 pm »
I am also interested in a pair of the triples subs.
This is my first post and I will add more to allow for pm.
mdl62
« Reply #305 on: 31 Dec 2017, 01:13 am »
What is the weight of one triple sub?
I have a couple of listening areas and am concerned about ease of moving them.
Mike
mdl62
« Reply #306 on: 31 Dec 2017, 01:15 am »
I don't have much painting experience or skill.
Some have had their units painted by commercial painters or car repair shops.
How much does that typically cost to have done?
mdl62
« Reply #307 on: 31 Dec 2017, 01:21 am »
The 370 amp for these subs on the GR website has one version.
The Rythmik website has multiple versions, including one with balanced connections.
I think that the GR version may have some other features and upgrades also.
Can someone please elaborate on that?
Mike
mdl62
« Reply #308 on: 31 Dec 2017, 01:24 am »
What would be the widest size clamp that I would need for the triple sub for glueing?
mdl62
« Reply #309 on: 31 Dec 2017, 01:28 am »
I have a pair of Magnepan MMGs and a pair of 1.7s.
How does one add in inline filter to limit the signal to the main speakers?
I believe there was a mention of that earlier in this thread for Maggies.
The result was that the Maggies required less power from unloading the lower frequencies.
Mike
« Reply #310 on: 31 Dec 2017, 03:55 am »
Mike
Wel. I've never actually weighed one assembled but, you'r e looking at 90lbs per triple flat pack (shipping weight), then it's about 22lb / woofer , wire , and no-rez so   le's say for sake of argument,    160lbs finished.
the modulars would    be very similar even though they are  1.25"  Medex   as opposed to 1.5"  MDF for the non-modular version
jay
« Reply #311 on: 31 Dec 2017, 03:59 am »
It really varies but  I can tell you  it is not  "cheap".   I'd say around $1300 is  minimum and it can easily  be  MUCH more especially  if you need to pay for asembly and prep.
Some of the House of Kolor  paints we've used  get pretty costly but man, they are cool
jay
« Reply #312 on: 31 Dec 2017, 04:03 am »
Mike
features of all should be very similar although (I'm not 100%% sure) I don't think the high level inputs are functional on the balanced  version. One  thing you  have to specify is that  the amps will be used in OB config...  a shelving cirucit neds to be added before they ship  them out to you.
jay
« Reply #313 on: 31 Dec 2017, 04:06 am »
18"....  I like to have a minimum of 6,  more is obviously better.  Never too many clamps  :)
jay
« Reply #314 on: 31 Dec 2017, 04:11 am »
Mike
Once yo u know the main amp input impedence, yo can   determine the size of cap  required to basically high pass them  the signal you want.  Use a high  quality cap.  If you don't want to build this your self,,  I think   has been known to make  some  nice inline  units that will work for you.
jay
mlundy57
« Reply #315 on: 31 Dec 2017, 05:00 am »
jay
If you order through Danny he will be sure Brian adds the appropriate boards and caps/resistors as necessary. If you order the amps directly from Rythmik you have to tell them what drivers you will be using in addition to open baffle.  Any of the A370 versions work. your choice should be based on what works best with your system. I prefer the A370PEQ3 for my speakers but a client had me build his with the A370XLR2s.
Mike
mlundy57
« Reply #316 on: 31 Dec 2017, 05:03 am »
Mike
In addition to what Jay has said, the filter goes between the preamp and power amp. If your preamp and power amp use balanced connections you will need to build a balanced version of the filter. The only difference is for balanced you will need two caps per channel. One for each hot wire.
Mike
« Reply #317 on: 31 Dec 2017, 09:44 pm »
Mike
Or,  you can open up the amp  and add the cap inline to the inputs, less cable   and connectors.  Some may prefer this  ....
jay
mdl62
« Reply #318 on: 1 Jan 2018, 07:15 pm »
Thanks for all the info and replies
Mike
HAL
« Reply #319 on: 2 Jan 2018, 01:57 am »
Going to start the glue-up of my modular 2x12 H-Frames tomorrow.
I am thinking about using Titebond II glue as before, but does someone have a better recommendation for adhesive?  All I have locally are Lowes, Ace Hardware and a local hardware store.  That limits selection a bit.
Let me know.
