Multi Bit Screwdriver
Doublej
« on: 14 Dec 2015, 11:18 pm »
I need a good multi bit screwdriver. What do folks recommend?
aldcoll
Re: Multi Bit Screwdriver
« Reply #1 on: 14 Dec 2015, 11:47 pm »
Pick them up and Hold them in your had.  My favorite or the one I go to is a 20+year old Snap-On.  It's handle fits my hand but it was a extreme failure as the cap on the end for the extra bits was coarse threads and came off in the lightest of breezes.   It also is one that the hex head for the bit is Well Made and a Strong Magnet.
And that is the only snap -on tool I own outside of my Grand Fathers 1930 (?) Blue point 1/2 inch early hex head wrench.
My $.02  Alan
timind
  • permanent vacation
« Reply #2 on: 14 Dec 2015, 11:56 pm »
Absolutely love the Craftsmen autoloading multi bit screwdriver. They come with quality bits and the best part is in ten years I've never lost a bit like I have with every other multi bit I've had.
As for the handle fit? Well it's perfect for me, plenty of torque when you need it.
http://www.sears.com/craftsman-autoloading-multi-bit-screwdriver/p-00947380000P?sid=IDx01192011x000001&gclid=Cj0KEQiA7rmzBRDezri2r6bz1qYBEiQAg-YEtsQ37Eo-7X4vdfq2_Fdf_dCO-5R-TF0Fb4xOx-SWG7QaAiH18P8HAQ
Folsom
« Reply #3 on: 15 Dec 2015, 12:09 am »
I prefer German made quality. Check out some stuff at KCTools.
