i broke down and ordered some silclear
0 Members and 1 Guest are viewing this topic. Read 5218 times.
Mike B.
Re: i broke down and ordered some silclear
« Reply #20 on: 6 Jun 2009, 05:38 pm »
I have heard and seen pictures from tube equipment manufactures about damage to sockets. Contact Victor at BAT and have him send you a photo or two of sockets he has had to replace due to treatments applied to tube pins and sockets. Just a friendly caution  :D
DaveC113
  • ZenWaveAudio.com
« Reply #21 on: 6 Jun 2009, 06:04 pm »
I would agree if your system already sounds bright and forward that adding silver contact paste is a bad idea. Just find the best solvent for the silclear grease and remove it, then maybe add some gold-based contact enhancer, you'll probably like that better.
I liked the effect of Silclear on my system, fwiw.
satfrat
« Reply #22 on: 10 Jun 2009, 12:44 am »
As do I but I'm not using it on any tube pins as the tubes in my Butler Audio amps are hardwired into their sockets. But I use Silclear on most everything else, all my speaker/IC Digital and power cables. I've even touched up fuse holders and iEC terminals. I've never experienced any of the issues that the King has, thank the gods. From Silcear, I get extra clarity from the highs in my sound stage which is airy and well behind my loudspeakers. :D
Robin
Bob Wilcox
« Reply #23 on: 10 Jun 2009, 04:09 am »
I used Silclear on all tube pins, PC males pin and some of the rCAs. Thsi stuff is making mystem sound bad. I get splashy highs and a more forward soundstage. I have used Isopropyl alcohol, acetone mixed with water, pipe cleaners, qtips and I stil can't get these effects out of my system.
Can someone please suggest what I can do as Mapleshade is not returning calls or emails.
too cheap for the high $$$ stuff so i grabbed one of these.
i have all my audio parts and a little room treatment  so time for some cheap tweeks :mrgreen:
Try Pro Gold spray on a Q-Tip.
turkey
« Reply #24 on: 10 Jun 2009, 12:35 pm »
I know another person who also feels that Silclear damaged his system, and Mapleshade basically told him to go to hell.
I think he's planning on taking them to small claims court.
turkey
« Reply #25 on: 10 Jun 2009, 08:47 pm »
I goofed. It isn't Silclear and Mapleshade after all. It's some guy named Walker and the goop that he sells.
