0 Members and 1 Guest are viewing this topic. Read 16294 times.
Hmm. I think the vinyl camp uses more opinion as fact than the digital camp. The SNR/Dynamic Range differences between digital and vinyl are very significant (well over 20 db in many cases). Vinyl playback also has to deal with wow/flutter, high frequency loss over time with repeated playing of the records, cartridge/tonearm alignment, and the list goes on and on. There is also the low frequency rumble effect to deal with.
I think the takeaway from Bob Ludwig's comments is that the potential for a more faithful recording of the performance that was heard in the studio is possible from the digital medium than it is from analogue mediums, vinyl or tape. On paper I think this might be true, but we will always be at the mercy of the producer for what happens to to the final product. The way I see it producers have a lot of Karmic debt to pay.Scotty
Some things sound better on vinyl some sound better on CD. I don't know why this stuff has to get rehashed over and over.
But you gloss completely over the difference between what digital is capable of delivering and what it typically delivers. I will concede your point when you can show that the vast majority of digital content being produced actually takes advantage digital's strengths. Until then your argument simply isn't credible because you are making unfounded large-scale assumptions about the content.Now if you care to present some specifics, good examples of recordings that were issued on vinyl and digital, then we might have something to discuss. But it is still just a few examples and you cannot reason from the specific to the general. It doesn't work the other way around because brick walling and dynamic range compression in digital mastering have both been long-established as a common practice.--Jerome
I was referring to the brickwall anti-aliasing used at the 44.1 and 48 kHz sampling frequencies. I too look for clipping on an album using Audacity software. There is really no excuse for clipping unless it is done on purpose for the nasty sound it produces. I was surprised to learn that it is considered desirable contribution to their "sound"by some artists. Scotty
Digital files are definitely capable of outperforming vinyl, however there have historically been a lot of roadblocks for digital that prevented this, including:1) Jitter, which is more prevalent with typical CD players and less of a problem with computer playback. Not easy to tackle by the designers and parts that render really low jitter systems tend to be pricey. Only in the last 5 years have solutions been available to reach really low jitter levels, and this is required to compete with vinyl.2) Digital filtering. Even the best hardware implemented digital filters seem to fall short, even the latest Apodizing ones that eliminate pre-ringing at the expense of post-ringing. A case in point is the popularity of NOS DACs that have no digital filtering. One such DAC from Audio Note was just reviewed in the latest Stereophile. Terrible measured results and yet the listening reviewer thought it was very natural and analog sounding.3) I/V conversion. There are many ways to achieve I/V conversion from a D/A chip. Some of these sound better than others. All have some sort of drawback.4) resolution. This is quickly becoming history as many companies are offering hi-res files for download.5) format conversion. This is primarily a new problem that appeared with computer file playback and the lossless and lossy compression techniques that followed in order to save memory. None of these formats seem to be free from artifacts, or at least the playback CODECs are not free from artifacts/distortion of some kind.The good news is that most of the above roadblocks are being tackled by good designers, so digital is sounding a lot like and even better than vinyl in some cases.Vinyl playback on the other hand has fundamental physical limitations, including:1) bandwidth of the modulation of the grooves2) bandwidth and linearity of the cartridge - limited by the magnetics, size, mass, wiring etc..3) speed control of the platter4) WOW of the platter5) dynamic range due to stylus pressure6) angle inaccuracy of the tonearm7) inaccuracy of the RIAA curve in the preampThese are much more difficult to overcome with new technologies IMO.Steve N.
Many of the recent recordings I am referring to are simply not available on vinyl. I'll do a search to see if some of them were issued on vinyl as well as digital. I rather doubt it, but I'll look.See if someone you know has a copy of the recording I listed above. The dynamic range on that one is major.
