0 Members and 1 Guest are viewing this topic. Read 8413 times.
If you are talking MusicBee, leave the check-box unchecked.This option is intended for onboard audio running at 48 onlyIf you are talking the sample rate in the Win audio panel, set it to something.As you are using WASAPI in MusicBee this setting is ingnored.
Really odd that Foobar kept it from working
